After lugging my RTT, and all of my gear around in the 100 series... I quickly decided that I wanted to get the weight off the top, and decrease the wind resistance of a brick on top of a brick.
I researched, scoured high and low, before finally finding the perfect candidate: a 1967 M416. I picked it up for $750 - so the price was right and I knew I'd be happy with having this as my canvas.
6 months later... It was time to go to work. I rolled the axle out from under it, and started to clean her up.
The PO did a sloppy job painting it with Latex. A friend and I did a M35A2 two years prior, and was much cleaner... apparently he didnt read that rollers spread more evenly than a brush.
I cleaned up the frame with a wire brush on angle grinder, and similar tools for drills, knocking away scale, loose dirt, etc. I then applied Krud Cutters "The Must for Rust." The jury is out on this.
I hosed her down, applied TSP-Substitute spray, hosed it again, and then applied a product that has done well by me - Eastwood's Rubberized Rust Encapsulator. I sprayed some rock damage on the Hundy last year and its been great. Should do the trick for this.
The next task was to sand, sand some more, apply primer filler, and sand some more before I gave up.... its not going to be a beauty queen.
