What have you done to your 100 Series this week? (31 Viewers)
Installed Fox 2.0 shocks, Goodridge stainless steel brake lines, EBC ultimax brake pads and Motul brake fluid. Also painted the wheels satin black.
Truck stops amazingly well and the pedal feels nice and firm. Love the way the shocks handle compared to my old OME, I thought for sure my OME were blown but to my amazement they still rebounded after compression but damn they were harsh. The Fox ride much more like stock and soak up the bumps very well, nice, soft and comfy.
Also sold my WKOR sliders and ordered some ARB steps, just waiting for them to come in stock.
Finally, got a Speski cargo barrier and it should arrive tomorrow.
nice work CK...i like your rig,,,here is it"s twin,,,almost?
MAF 80 series extended rear sway bar links with new OEM bushing in the bar, Super Pro Poly bushing in the steering rack, and the best one yet, new Velcro on the third row...
Tires
I picked up some new (used) tires from Spresso. 285/75/18
A little mock-up...
Next on the list:
- AHC Override from Slee
- Diff Drop
- 30mm Rear Spring Packers
- 1" BL
A little mock-up...
Next on the list:
- Diff Drop
- 1" BL
If you can get them to stick out that far, Silverhorse wants the details...
added an outlet to the rear
made a "skid" for my low hung hitch using an extra hitch/ball cutting it and flipping it around
Big weekend on the 100...
Slee Diff Drop.
Greased and re-clamped the CVs.
New brake pads on all four corners.
New speakers in all doors.
New FrontRunner roof rack.
Sent from my iPhone using IH8MUD, and hopefully approved by the NSA.
Chased down two wires that broke loose, had no speakers on drivers door. Sounds much better now...
Lube job all around, engine oil, both diffs and transfer case, drive shafts. Glad to see that there was only dust on all the magnetic drain plugs-at 212k, been 30k since last drain and fill.
Finishing up on the FF Dana 60/GM outers for the arse end. And coming down home stretch with the nose side SAS.
Just mess'n witcha :D
Front transfer case seal
Finished Timing belt
Ran power to the back to blue sea
Wired fridge
Wired inverter
Wired shower pump
Wired/installed 32" LED light bar
Rerouted my shower/installed stainless quick disconnect on front bumper
Now it's beer-30 and German grand prix time.
Wired fridge
Wired inverter
Wired shower pump
Impressive!
Replacing the carpet with this sheet of stainless steel is quite possibly the best thing I've done to the 100 so far lol. HUGE improvement! :D
Inspection list for 1,500 mile trip...
Kicked tires to verify they have air...check
No oil on the ground...check
Topped off blinker fluid...check
Made sure dirty air filter installed...check
1 gallon of plastidip into gas tank for 100MPG...check
Pastidipped engine bay for 1,000HP...check
You forgot the hemorrhoid cream
Removed the faux wood trim
This process lived up to the "painfully slow" description.
Made it very dirty first, before cleaning it again.
Cruiser Hound, was there any glue residue under the faux wood? If so how did that remove? I'm also assuming there was just "black" plastic under the faux wood? Too cool!
Meanie.
Nice choice of brew. :-)
Drawers! ... almost
So Close....
Final Hardware and Installation Tonight, can hardly wait!
