What have you done to your 100 Series this week? (30 Viewers)
I turned mine into a farm sprayer. The sprayer was designed to go over the tailgate of a UTV so it worked great with the tailgate on the 100. Newly cleared paths on really hilly terrain with some tight turns, stumps and low muddy areas. Stock LC did great carrying about 450 extra pounds of roundup in the back. Had a lawnmower battery on the floor in the back seat with a 12' lead with on/off switch. Could control spray while driving. Doing this so I can hopefully throw a nice whitetail in the back this deer season!
Next time you spray let me know I’ll walk behind and make sure nothings missed!
Changed the oil and greased the drive shafts this morning.
Then found that the o-ring on the water inlet housing has a very minor seep after about 200 miles. I don’t think I used enough lubrication when installing and must have damaged the o-ring.
Oh well...I needed another project. 😕
Clean it really well… see if it returns.
It is not unheard of for the water pump to weep while is running in. Not very common, but not unheard of.
I hope you didn’t damaged the o-ring because when I did mine I pinched it. Second time I did it was a charm as I made sure to apply die-electric grease on the o-ring. Best of luck!
I did damage it :(
It was pinched and shaved parts of it off. Had several flat spots. Bush League mistake.
I did damage it :(
No worries buddy we live and we learn. Was a lesson more than a mistake. Die electric grease on the o-ring and die electric grease on the housing and you should be good.
Side question: Does it have to be dielectric grease or can it be regular grease? I'm about to do my thermostat and it's the same set-up...little rubber ring that gets squished in between the outer housing and the water inlet housing.
I have never put any sort of lube on the thermostate gasket/seal. The thermostat housing sandwiches it inplace.
Damaged o-ring. It’s like that about 40% the way around the outside.
Mine are coming due... how much of a pain in the ass are these to change?
It is not difficult. Just have to work each side back and forth at same time to keep lined up. But not difficult it all.
Annnnnnnd my AC has packed up. Was working fine then just stopped. I see it could be a failsafe that if the pressure drops the AC just doesn't kick in, so hopefully a regass will sort me out. Hopefully that's all it is, I cba with more expense!
I got sick of the distortion coming from my ML sub. I've replaced all door speakers a while ago with I think JBL, I honestly don't remember. But, I re built the sub and it worked well for a while. The distortion has gotten worse so I replaced it with this. It's def. more clear now but it doesn't hit heavy with bass like the pictures suggest. Probably time for an amp upgrade but I'm not going that deep into the audio. I've got other stuff to address for now.
Hey how do get to the sub? Haven’t scoped it out yet but going to give my sun some fresh foam.
