What have you done to your 100 Series this week? (33 Viewers)
Love the picts! I do want to point out the spring clip at the under the front leading edge (on the pointy side pointing to the front of the car) in that window roll-down button panel is a bit of a pain. Use something flat to push it back and lift the panel up and out of the door panel. I broke one once, although I found a new spring clip to buy (Part #: 90468-05114).
Yeah I was gonna say the biggest pain was removing the window controls. What I did was slightly pull it up from the front (front of car) and then you can see the metal pin underneath that holds it in place. You can then push that metal pin in with a flathead and it comes out easily.
What size tires did you go with? That will be my next upgrade after my refurb and suspension work is done. BTW, I have KO2s on my 4Runner and they have performed and held up very well. I don't think you can go wrong with them.
Went with 285/70/17. Had a little issue with rubbing but fixed it by hammering down the pinch welds and trimming some plastic. Ive loved my KO2s, going on the 2nd set and still no issues.
Appreciate it! 17x8.5 5x150 with +15mm offset
Nice. I am running the Echos on 18x9 offset +25mm
I am eager to test out the dual air valve for airing up and down.
It’s amazing what you hear when you turn the subwoofer down a little…
Looks 1337!!
Did you have those stickers ready to go for the rack?
Thanks!
I did, I had just been keeping stickers for about a year now with this in mind. Have a few more after the Central Texas Land Cruiser Roundup today that'll go on soon.
Today I received my rhino hitch lock in the mail and it doesn’t fit… lol.
Anyone have any recommendations for a hitch lock?
Changed my front differential and transfer case oil and added some grease to the driveshaft. Not sure if the front diff and TC had ever been changed. Possibly but sure looked and felt like those fill and drain plugs had never been removed. Oil was pretty dark. Not much on the magnets which was nice to see.
