What Did You Do with Your 80 This Weekend? (71 Viewers)
Threw some 1 1/4" spacers on my 33's (I know, not necessary but vanity took over), and did some climbin' around the Verde River...amigos!
That's Big John double checking my work.
Here's a fellow cruiser climbing a hill... land cruiser do what a land cruiser do
Had el luncho' at Devils Hole on the Verde River...sorry, no pic
Zona
Nice! What's your buggy based on?
image-jpg.1064869
It's my old work truck. A 1990 dodge dakota longbed. My dad gave me a sand rail chassis and I removed the floor, cut it in half, then lengthened it and welded it onto my bare chassis. Thing is a blast!
Took three kids from my school (I work at an 80% poverty middle school) to go pick up 30 tablets I got donated. The kids loved riding in my 80 and couldn't believe that it was 23 years old. We showed up to pick up the tablets and they also had a charging cart for us if we had a way to take it! Woohoo! Another teacher had suggested taking her Prius. Good thing we took LC!
On the way back to the school we talked about camping and off roading, all the places I've taken my kids in my 80. People wonder why I am so attached to my 80 and love it. It isn't just the reliability, durability, or general bad assedness of the 80 series. It is all of the time that I have gotten to spend with my family in my 80. The experiences that I have been able to share with them.
Worked on fire carrier some more and removed the old reciever tube from the bumper since it stuck out too much and was pointed slightly down and looked terrible. Installed a new tube set farther back and am doing some other mods soon. Have a few parts still coming in the mail.
@zona I'm sure you already know but after 100 miles, take off the tires and re-torque the spacer! This is critical.
I certainly will re-torque on the spacers--I appreciate the reminder--also, thanks for the tip on Mobil 1 Turbo Diesel 5w-40! I will run it in the rig forever.
Zona
Was almost the weekend when I had a little "fun".
Thursday evening I went to pick up this toolbox I was given and started feeling a bit of vibration. I was towing my little trailer with old KM tires, so thought it must be coming from there.
Only was able to fit the top half of the box in for this trip.
Friday morning I'm heading to the shop, got an early start because I'm taking it easy while towing the trailer, and I'm still feeling this vibration. At this point, I'm sure it's coming from a tire, so I'm half-expecting something to happen. About 5 minutes from work, it happened...I hear a loud flapping and look in the side view mirror to see the left rear tire in shreds.
It actually threw the chunk of tread off first, then started losing air, so there was no loss of control or damage to the rim. There was a little damage to the fender, though.
As with most mishaps, I learned a few things. First, if you have a vibration that feels like a tire, get out and check them. Chances are you will be able to see it and get it taken care of before things fly apart. I could have easily changed this in front of my house with my floor jack and an impact wrench. Instead I was doing it on the side of the road with my HiLift, which leads to the second set of lessons--Using a HiLift is not as easy as it seems, especially if it has just been hanging out on the back of your rig, not receiving regular cleaning & lubrication.
HiLift lessons:
#1: If you are not using the off road base that is available and don't set the parking brake on the vehicle, it could start to tilt and possibly fall. I watched mine angling toward me as I was trying to get the lug nuts back on the spare, and didn't want to spend much time in the path of that destructive bar. I ended up hopping in through the passenger side and inching back in reverse until the jack was upright again.
#2: When pins are sticking, the lift will not want to lower the vehicle properly. My lower pin wasn't releasing when the handle was brought down, so I ended up having to pull it out each time by hand. The last time I did this, that pin didn't slide back in to its lock position, so when I raised the handle the upper pin released and the final 10 inches of lowering happened quite quickly. That's how I ended up flaying open the knuckle of my right hand.
All in all it was a learning experience, I was only 10 minutes late to work, and now I need to buy some new tires. These KM2s were used when I bought them about 4 years ago, and have been showing their age. The 60" HiLift proved its worth as it was reaching its upper limits while using the lift point on the 4X4Labs bumper to get the rear tire off the ground.
It actually threw the chunk of tread off first, then started losing air, so there was no loss of control or damage to the rim. There was a little to the fender, though.
HiLift lessons:
Ummm....Why would you not use the factory Toyota jack? It is definitely short enough to fit under the axle with a flat tire and will go tall enough to lift the wheel off the ground.
I have wheeled for LOTS of years, and have never had to use the Hilift to change a tire because, as you experienced, it becomes very unruly to manage because you have to almost lift half the vehicle off the ground to be useful. Plus, when you have the corner off the ground, the drive line on these trucks will NOT hold the truck in place. The Hilift has typically been used for fixing the fence I just drove through, moving a tree out of the way, or splitting a tractor in half to do an engine rebuild, but really have not had a great need for it. I guess I used it last week to do body work on a car.
I would agree, though, it looks cool having it hanging off the truck somewhere for everyone to see. No, I'm not being sarcastic here.
Old and new
Just engage the lockers before you jack it up. It won't roll.
Of course....assuming one has lockers.......and a CDL.
Huh... Some people don't have lockers? Weird.
Seriously though every 80 has a CDL. If you don't have the switch you can just drop it into low.
