What Did You Do with Your 80 This Weekend? (41 Viewers)
I bought mine, brought it home yesterday (Saturday)!
So far I've replaced the amber corner lights with clear ones (driver side was broken) and done a ton of cleaning. Needs a windshield and I have to diagnose a possible faulty brake switch (brake lights don't always work and won't shift out of park unless you jiggle the STOP relay) but should have it roadworthy soon!
This is how we all started…once you start on this path there is no turning back😂
Took it to the range to sight in my match rifle.
Second picture is my kids spotting shots for each other and calling impacts/misses at 500m. Good times.
Installed a pair of Trail Trailer extended length rear sway bar links under my 1997 FJ80.
Turns out this was a timely parts replacement - one of the lower link bolts was loose, with the nut soon to be on it's own! :D
Does this look like coolant or transmission fluid? I can't quite tell where it's coming from at first inspection. View attachment 3690782
I am betting it is a coolant leak as that does not look like an oil stain on the concrete. Check your fire wall hoses, heater valve and then the hoses and lines going to the rear heater.
