1993
I realized today I have an lspv. I always thought it was abs only. Guess I need to research a delete for non-abs 4 wheel disc brake rigs
Thank You I will lQQk into flushing system. Will radiator show flow with cap off? In for the long haul is there a link for complete parts and redo options,, in Florida truck will do 3k per or so this trip was a one off journey Karl
Good morning did a restart on truck , the compressor is coming on fan blows . Not Cooling can I try a can of parts store freon? Thank You ... The ac compressor lQQks new and I fiddled with a Hot wire . That replace two clip ons. Attached to block switch. Thank You In advance
I am in the same boat. I have a new lspv ready but not sure if I am going to use it. I have non abs 4 wheel disc brakes as well. Nothing leaking back there but the rubber boat has a nice tear in it.
Replaced the Speedo gear o-ring, distributor o-ring & all three belts. The old belts were in fine shape but weren’t OEM and had the teeth/v-belt profile. Purchased these replacement parts back in March 😂. Just wasn’t motivated to do the belts because the alternator tensioner is a pain in the butt.
Just had a great week visiting my sister and brother in Virginia Beach . It was a 600 mile one way trip . I had my wife ,2 daughter and grand baby with me . I took out the 2 back 3rd row seats for more room . While at my sisters house she had a new dishwasher delivered so I installed it for her . There was nothing wrong with the one I took out and my daughter needed one so thanks to room behind the 2nd row seats the dishwasher fit with all the luggage around it . While at my brothers house I took the after market head unit out and rewired it into the plugs that went into the factory amp . It got rid of the engine whining I was getting through the speakers using the factory amp wiring connection . In the lx450 you have to bypass the factory amp if you install a aftermarket head unit or you will have a whining noise from the engine into the speakers . I now have a great sounding system . I have been putting up with the whining noise for 11 years . My brother helped me with the wiring on the glove box side and I did the wiring on the radio side . On the way back I stopped at my daughters house in Asheville NC and installed the dishwasher . She loved it . I noticed the water heater was leaking water so I went to Home Depot and flopped down one side of the 2nd row seat and slid in a new water heater with room to spear . That's one thing I really like about the xl450 is it has all kinds of room . I installed the new water heater and she was very happy . I'm never going to sell my xl450 .
Not all this last weekend but I've been making progress on getting ready for a upcoming trip
Over the last month or 2:
-New 37×13.5r18 bfg km3s
-Water pump, timing belt, rad hoses, thermostat, rad flush, rad flush, rad flush lol
-Confirmed oil pressure was good, 26 psi at idle, 67 at 3000rpm (dang gauge cluster had me all worried with it's wonky readings)
-Set the valves
-differential/transfer case oil change,
-built a bed platform, set up fridges underneath, and made some window shades for the sleeping area
-new tie rod end
-had the clear coat freshened up and remove almost all scratches
Still to do:
Replace A/c compressor
Install prinsu roof rack/pelican cases
Probably a few other things I'm not remembering as well
Very clean work and an even cleaner shop! I love the paint pen marks to verify torque!!!! Nice attention to detail.
Thank you. Appreciate it.
I’m lucky to have a dedicated, HVAC-controlled clean room to build important assemblies like engines.
-Set the valves
-new tie rod end
Still to do:
It's funny. I just did the same thing with my oil pressure and mines identical to yours.
