What Did You Do with Your 80 This Weekend? (25 Viewers)
Got a link for those lights?
This brand is run by box rocket also and he has good things to say about them
Very nice. My stock setup is sad. What housing do you have them in and any special or complicated wiring needed to run them?
Thanks. They’re depo housings with led projectors so the wiring is the east part. I’m still trying to figure out how to get the mled high beams to trigger.
More details here:
Put it on a diet
I'm hopeful that I fixed the issues that wipe the firewall steering shaft seal out. This will be a much more permanent fix than just replacing the seal. No more hot driver's feet for me!
More details here.
How did you wire them? Did you order them with the switch?
Thanks
I already had a switch wired up with Toyota style rocker switches, and a relay to a two pin plug. So all I needed were the lights. You then take the daytime running light wire that come with the lights and wire them in to the power plug for the corner marker lights next to the headlights, it’s super easy, and a green wire on mine. If you don’t have a wiring harness, you can get one from any of the aftermarket, light companies or get one from these guys and just buy a better switch so it doesn’t look as aftermarket.
Thank you.
Axle going back in for the last time tomorrow and hopefully get to try out the new 3 link. Need one brake fitting Im hoping I can find in town tomorrow morning.
I got these same lights back in NOV black Friday sale and getting ready to wire these up. Do you know if you can supply power to both the yellow and white DRLs at the same time? For example, power to white DRL is from IGN on source. Power to yellow DRL is from turn signal source. So when yellow DRL gets power, does the white DRL automatically turn off and the yellow DRL comes on? Not sure if power to both DRLs would short it out once the turn signal power is supplied. Any answers appreciated.
