Upper control arms. A little more difficult than I thought since the bolts are removed towards the springs and there's not enough clearance. I used the hi-lift to jack up the drivers side and pull the bolt between the coils. I only wish it was that easy on the passenger side. I had to jack up the rear to pretty extreme heights, remove the shock, and the sway far for full droop, and rotate the spring before I could get the bolt out.
I reinstalled the bolts reverse from the factory. I can't use an impact on the nuts anymore but removing the bolts is a LOT easier.
Oh and once again the mechanical jack saves the day and makes fine tuning easy.
