What Did You Do with Your 80 This Weekend? (101 Viewers)
Put on a factor55 fairlead, ultrahook, and adjusted the panhards again.
After 13 years and 240,000 on top of the 150,000 miles when new to us, I finally built a drawer system.
The truck wasn’t brown, but it did deliver a cool present. I wonder what’s in this huge box.
No opening video needed. Just pictures of things that will last my lifetime.
@Onur knows what all that means. Looks like it was manufactured in February 2019 though. Kind of cool. Actually, that’s really cool.
I understand the next better.
Congratulations on the new short block, that's exciting. I'm going to sharing with you from my experiences with new Toyota short blocks. During my 80 rehab I've had two brand new short blocks in the last 12 months. The first one, with Joe Gibbs Driven break in oil, had an issue and the piston rings didn't seat properly. it was the pits to deal with, down time, cost on new seals and fluids, etc. Toyota diagnosed it and warranty claimed it - great outcome there. The new replacement engine is in and running perfect now. The break in process I now follow was suggested by Robbie. 1st 500 miles on conventional oil, Change it and run the same kind of oil for another 500 miles. Then change again with the same conventional oil and run for 1000 miles. Once those mileage markers have been hit change the oil again but switch it up with Shell Rotella T6. You may have your own system for breaking in an engine, hopefully you do and can avoid the lesson I learned.
cheers
Had my new 80 dropped off to 60/80 V8 Master Stan @NCFJ last night (huge thx again @Reservation Cody ) for a previous V8 swap clean up, new electrical and speedhut gauges install, Lokar Shifter install, Front Knuckle rebuild, get the A/C working and new bushings underneath to start.....
congrats. I had been eying the Clist add and had picked a couple likely Suspects for the Sylva area. Shoulda known.
Yea great Carolina guys! Lucky to get to meet both of them now. AZ Rig has great bones, no rust with the V8 swap already done. A little TLC will make this rig a beast!
In celebration of the 300K mile birthday, I gave my 80 a little love.
* New Under hood fuse block cover. (I could no longer read ANYTHING on the old cover)
* New PCV Valve
* New PCV Hose (and clamps)
* Cleaned out the PCV connection to the TB
* New TB hose VC to TB (and clamps)
* New vacuum hoses (the easy ones to the intake manifold, gas filter, EGR)
* Added a set of 350 Anderson Connectors and 2/0 battery cables into the cabin. Need to mount the terminal to the center console. THis is to power my current 1000W modified sine wave inverter. Eventually to power a 2500 W pure sine wave inverter.
* Wired my existing inverter with a 6 ft whip of 2/0 battery cables and 350 Anderson Connector so I can lay it on the third row seats to run my office computer and printer from the tailgate. Eventually to charge a power wheelchair.
*I have a bunch more new parts, but haven't installed them yet.
* Added new horns.
The new horns are a bit of blasphemy, but C-Dan will like it!
I used Mopar horns 6806 5260 AC-01 and 6806-5261 AB-001. Bought them from my local Mopar dealership. $50 for the pair including tax. (Don't believe a dealer that charges more than that! ($21 for one, $26 for the other) I was quotes $66 for ONE horn from a different dealership and I told him he was full of s***.
They fit beautifully, took me about an hour to install, working slowly.
Drilled the mounting bracket to 5/16" ID on each horn.
Built a ground wire for each horn and routed back to the bracket, about 6" long each.
Cut off and split the power wire from the truck to power both horns at the same time. I would have used the exiting connectors, but my wire was already broken. I think that the original Toyota connectors could have worked on the Mopar horns.
The Mopar horns require a separate ground wire from the horn to ground, whereas the Toyota horns are grounded through the bracket.
Five insulated female spade connectors, 14-16 gauge (blue)
Two 3/8" loop connectors, 14-16 ga. (blue)
One insulated male spade connector, 10-12 ga. (Yellow) (For the wye)
12" 12 Ga. red power wire
12" 12 Ga. black ground wire
Old
New
They clear the hood and mount like they were made for it.
The best part is they are LOUD and they can be heard!
The following are video links (I hope)
Old:
New:
Liked the horn idea so much, I ordered a set for my LX :) The 5261AB was replaced by the AC.
Got stranded on the side of the highway on the way to work :bang:
Got a flat and like an idiot I have never checked to see if the truck came with the bar used to lower the spare tire.
Surprise, it did not! Thankfully TDOT showed up and rigged up something to get the spare out.
Does anyone know where I can buy a bar to lower the spare?
I bought a complete tool kit and Jack from a salvage yard out of a 2007 Tundra. It had never been used and works great! I over paid at $100.
I had the same problem, no bar, so I made one with square tubing and a bit of round bar.
Thanks I wasn't sure if other Toyota models would work. I have the jack so hopefully can save some money and just find a bar
Found the following in my old parts collection. Missing one square head set screw which would be easy enough to replace with a hardware store bolt that you then squared the head of with a grinder. Could use some rust converter in a few spots as well to stabilize things. Glad to trade for something random/interesting or for a 6 pack of something interesting, I like cider :)
Let me know and I can PM you where I am (close to downtown) so that you can drop by to pick it up.
Getting hot here so I am just working on small simple things.
First was replacing the firewall steering shaft seal (from Wit's End). Very satisfying to replace.
Next, previous owner had installed manual locking hubs. Surface finish on the hub face was leaving much to be desired, so I took them off to clean them up and repaint them. Painted with metallic black night metallic and dark copper metallic Rust-Oleum cans. Replaced detent springs and little ball bearing along with new hub dial gaskets, and hub gaskets from Cruiser Outfitters.
I saw that the axles were missing snap rings on both ends - I suppose PO took them off and for whatever reason did not put them back on. Hub cavity was also overly stuffed with grease. Took out all the old grease and re-greased everything. Ordered snap rings from toyota along with new bolts.
When things cool down this fall I will clean up the hub body when I put in new axle seals.
Now that my hubs have been repainted the wheel paint is definitely looking pretty crappy. How involved would it be to strip the paint and leave them with just metal surface finish? Or would it be better to just repaint them black?
It might be time to get rid of the 100lb tire carrier (40+ HP); then, secure the tire in the back (20+ HP); or obtain a new bumper that holds the tire (30+ HP). . Either way, you'll gain at least 60 HP! Wahooooeeeee! let it fly!
Zona
