What Did You Do with Your 80 This Weekend? (45 Viewers)
Nice, mind sharing a link to that TPMS?
Something is up with links that is above my pay grade.
The Amazon link is there in the post. I can view it using Safari or Chrome but it is invisible when I view the post with Firefox.
I noticed I couldn’t see a link others where talking about in another post earlier today. Not sure what’s up.
To answer your original question, search Amazon for Tymate TPMS and it should come up. About $70.
Hmm, odd, maybe just throw up the product name and I'll do the hard work of copying/pasting :p
Just got my new Quad light assemblies and am going with J.W. Speaker Heated LED's for low beams,
I'm also gonna install my WAIC setup!
Gonna be a fun weekend!!
Whoops!! you are correct!!
Inside are high and the outside are low beam. I'm gonna wire them to have four low beams as the the High beams I bought have a low side to them. the J.W Speakers are Low beam only. I know its not technically leagal to have 4 low beams.. but I'm gonna give it a shot!
Post Death Valley trip found my starting battery had shaken loose and the positive terminal touched the hold down bar and fried my Slee Headlight relays and a few other circuits were acting weird. Ordered up a couple LCP battery brackets since I have that goofy off size 34.
Also found me a replacement steering wheel for $100!
Cut a new tailgate cover out of press board, covered with carpet and installed a marine hatch I got from Bargain Hunt for $4.00.
I was surprised at how shallow the tailgate is and how little space there is in there. I don't know why I was expecting some sort of Klein bottle to be inside the tailgate. I guess all those fancy tailgate storage lids captured my imagination.
View attachment 1938536View attachment 1938537
Why would you cut in the center, you can see on the opposite side how shallow it is, and be surprised??? Most of us put two doors on each end where it is deeper. Measure twice, cut once.
Post Death Valley trip found my starting battery had shaken loose and the positive terminal touched the hold down bar and fried my Slee Headlight relays and a few other circuits were acting weird. Ordered up a couple LCP battery brackets since I have that goofy off size 34.View attachment 1937886View attachment 1937887View attachment 1937889
Also found me a replacement steering wheel for $100! View attachment 1937890
It would be beneficial to fit a correct battery. The one you have in there is dimensionally too small and the posts are ass-backwards. That's a group 24 and you should have a group 27F. With the correct post orientation you would not have shorted out the positive terminal.
Slowly but surely getting there. I much prefer a 27F but got this one as a warranty swap from Sears. This battery was first used in the second battery PS location where orientation was good but the battery was still too small for fit and amp hours. Now have a group 27 in my second location and this 34R (775 CCA) as the cranking battery. Sadly, didn’t recognize the potential problem until it happened. Next battery will be a 27F, although for now the problem has already been solved with the use of the LCP bracket.
Found a square TPMS that fits nicely in my unused factory cigarette lighter port. It almost looks like it belongs there.
I just installed it so don't have any long term feedback but it seems to work fine out of the box. Has adjustable high/lo pressure alarms as well as displays temperature and voltage. The sensors are wheel specific and replace the valve stem caps. I think they will be fine for street use but could be knocked off off-road.
Amazon product ASIN B07HNPQ4X3
Also mocked up an inverter/air compressor cabinet that will go on top of the 1/2 drawer system I just finished. The open area to the left will house electronics (solar charge controller, circuit breakers, bus bars, etc.) and the drawer at the bottom is for air fittings, hose, and accessories. Hope to get it glued up this coming weekend.
Where'd you get that outlet/volt meter panel?
I started with the panel from Amazon below. The volt meter part worked fine but the outlets were too deep to fit in the very shallow space to work with behind that panel. I ended up finding raised mount DC power ports and using right angle flag terminals in the rear to make it all fit. Been in 3 years and no issues.
Search Amazon for Triple Function Dual USB Charger with Digital Volt Meter
DUDE!?!?!? you got the IC kit from the cali guy,?? sweet!!
Yep, been sitting on it for some time waiting for good weather to install it.
As I just got my quad light assemblys, its the perfect time to install both.
I have to remove the headlights on the passenger side to deploy a hole saw for the Intercooler coolant lines to the heat exchanger, so... I may as well swap in my new lights and corner markers.
  • Like
Reactions: RFB
Oh Shiite you did it, how bad was the fab did you do it all yourself?? it looks sick Im getting rid of maggiolina up top and frontrunner rack too top heavy and may go this route of GFcampers route.
What kind of puller did you use to remove the pulley from the Super Charger? I got a 3.0 Pulley I plan to swap in as well!
I show how in this video think I pressed it out
