What Did You Do with Your 80 This Weekend? (108 Viewers)
Fabricator (son in law) just dropped off new stainless steel running boards. Look good and will have a "C" channel or angle iron welded in the center under the step tread for strength, like the OEM running boards. Missy wants them painted black.
Why would i want to do this mod? Is the paperclip a failure waiting to happen? I have never noticed any issues with my steering.
I've never had any issues and I still have the paper clip, but I think anything you can do to keep your fluids cool is inherently good. The Derale coooler @NLXTACY used seems like a good upgrade to accomplish this.
For you guys that haven't seen the difference is between a 442 (1993-1994) and a 343 (1995-1997). Three of us lifted the 343 into the back of a (lifted) pickup bed. Might have been tough with the 442 ?
Ended up changing brake lines and bleeding my buddies HDJ81 for his inspection on Monday. Trying to get the car road legal this week.
Also found oil leakage at the turbo, further investigation required.
Local mudder came over today to assess his truck and see why it drove so squirrelly. Turns out the lift on the truck didn't have the panhards adjusted. This forced the front axle to the passenger side and the rear axle to the driver's side. He was also missing some bumpstops. But his biggest issue, and why it drove so harshly, was the driver's side wheel bearing was badly in need of pre-load. It was a wobbly mess. Luckily I had some spares to also replace his flange stud and hardware.
I was also able to berate him enough to remove his damage multiplier and strip out his aux light wiring so that it could be redone. Then ended with a smoke break :P
Finally, fitted my OME 2861 / 2 coils and new Tokico shocks. A mechanic friend let me use a lift and his air tools :) ..but I did the work myself, six hours start to finish. It's got +15mm spacers on the back and 20mm on the front, so there's just over an inch of "real" lift over stock, but approaching 2" over where she was before. but the difference to drive is huge, she no longer feels old and tired with a saggy arse, carrying the extra weight.
happy boy..
before.
after.
I was also able to berate him enough to remove his damage multiplier and strip out his aux light wiring so that it could be redone. Then ended with a smoke break :p
View attachment 1414261 View attachment 1414262 View attachment 1414263 View attachment 1414264
I'm a rocky Patel guy myself
I'm finally getting back into stock bushings.
For free... such a great deal.
screenshot_2017-03-03-17-04-49-png.1413547
20170303_172123-jpg.1413550
I still can't figure out how to get a Instagram vid on here yet, so click link for video.
Instagram Link
A bus load of nuns could be in danger somewhere:eek:
Awesome... I'm glad you sent the pic.
I was going to look for that memo.
When I press in my new bushings into my narrowed arms I will make the holes go horizontal.
I remember they changed the orientation around 94 or 95 I believe for better durability. Correct?
The buss load of Nuns is a old joke started by @Tools R Us If I remember correctly.
The buss load of Nuns have been in danger since I went to 37"s....
