What Did You Do with Your 80 This Weekend? (62 Viewers)
Took the LC up to Wahiawa Gardens.
Cool bridges...
Beautiful place, several miles of easy hiking trails, and a great place to unwind after a long weekend of working on the LC.
Did you use anything for castor correction? How's it feel driving it compared to previous?
Haven't done the castor correction yet. Have the OME bushings already, but just haven't installed. Wanted to drive it first, and was pleasantly surprised at how well it drove! No weird vibrations (even at 70mph on the freeway), no pulling side to side when braking, not stiff to drive at all. Don't really know what the castor correction will do to help as it already drives very well. I have them, so I will probably install, but is there any harm in not installing the castor correction bushings?
Haven't don't the castor correction yet. Have the OME bushings already, but just haven't installed. Wanted to drive it first, and was pleasantly surprised at how well it drove! No weird vibrations (even at 70mph on the freeway), no pulling side to side when braking, not stiff to drive at all. Don't really know what the castor correction will do to help as it already drives very well. I have them, so I will probably install, but is there any harm in not installing the castor correction bushings?
In addition to the weird vibrations some of us see, your steering will tend to wander a little bit more or feel a bit lighter without the castor correct due to the way castor affects the "return to center." There isn't really any harm in not installing the castor correction if your truck doesn't feel too loose on the interstate and there aren't any vibrations.
That said, you can always run by an alignment shop and get a printout to make sure it's in spec. If you do the castor correction, you might as well buy a couple of fresh bushings "while you're in there."
Jack
That settles it, sorry guys but I'm only posting pics of my wife driving the LX.
I believe I can speak for all of MUD... THANK YOU!! I've seen enough of your hairy feet to last me a lifetime.
Jack
Yeah, no weird vibrations at all (yet) and the steering doesn't wander at all. I let go of the wheel at several different speeds to test it and no drifting, drives super straight. In addition to the castor bushings, I ordered a new set of sway bar bushings for the front and rear from Beno...any other specific bushings you would recommend I replace while in there?
Got my new IPF 968's installed and up and running. Just waiting on my Slee harness and Switches from Frank to finalize them. Also working on relocating my Solenoid box for my winch up under the hood by the battery.
Pretty sure this is the only part of the post that @retrofive comprehended. And guessing he wasn't the only one...
I um, OK guilty.
No suspension upgrades necessary in my opinion.
:grinpimp:
Drained/filled diffs/ transfer case. Two years since the last time. If you do any water crossings, even if you have axle breather tubes, figure on changing that stuff out sooner than later.
:doh:
Is this a threat? It's either you or your attractive wife?? Oh no! Lol
:doh:
Things looked OK though. Rear diff drain plug collar thingie was interesting. Rocks happen, apparently.
