Took care of some surface rust on the rock sliders and the rear sway bar. Also installed a new fuel cap hanger….for the new fuel cap.
Quick run up the mtn this morning to get my steps in. And it was 9/1 so of course the gauge had to tag along. Managed to jump about 9 birds but only managed to get one. They were in some super thick pines.
Quick run up the mtn this morning to get my steps in. And it was 9/1 so of course the gauge View attachment 3982996had to tag along. Managed to jump about 9 birds but only managed to get one. They were in some super thick pines.
Nice I took the girls out this morning in Oregon and didn’t see a single grouse, did spot a couple bucks for October though.
Drove to Reno to play golf and dispersed camping. The weather reached 101 and the ECT stayed under 200 on the mountain passes but the IAT was 145 at the highest. I see a stainless dorkel in the near future!
Finally found a good solution for attaching Mountain Hatch tailgate cover more securely.
The vinyl "Christmas Tree" push rivets that come with the cover loosen up over time, especially with fluctuations in temperature. Replacing them is cheap enough, but it's a short-term fix. Wrapping the threads with Teflon tape secures them a little better, but again only for a short while. Slamming the tailgate closed a few times and sure enough, the cover is loose again.
I tried these zip ties that have a sort of toggle bolt end on them, and conceptually it would have worked but they just weren't strong enough and kept breaking.
Finally I decided to go with rivet nuts and actually bolt the tailgate cover to the tailgate.
I used M5 rivet nuts and 30 mm M5 bolts with vinyl washers to prevent the bolts from cutting into the tailgate cover itself. It is super secure, and easily tightened should it loosen. Down the road I may replace the bolts with something with a wider head, but for now this is a great solution and minimally invasive.
Never worked with rivet nuts or used a rivet nut tool before, but it's super easy. And now I'm going to be looking for ways to use these things lol.
Been thinking about getting one, what's your opinion on this?
found a place to get lost, and stay lost for a short while.
the dog tried to do the same
Stuck in Colorado (it could be worse I guess 😁) with a short somewhere in the taillight circuit. People have been telling to check the harness at the rear crossmember. Does anyone know if the wire harness for the rear lights comes down the driver's side? I disconnected 2 wire connectors but I am still getting 12v across the terminals in the fuse block. If that's the case then I don't think that is where the short is.
Stuck in Colorado (it could be worse I guess 😁) with a short somewhere in the taillight circuit. People have been telling to check the harness at the rear crossmember. Does anyone know if the wire harness for the rear lights comes down the driver's side? I disconnected 2 wire connectors but I am still getting 12v across the terminals in the fuse block. If that's the case then I don't think that is where the short is. View attachment 3983557View attachment 3983558View attachment 3983559
Reading 12V across open fuse terminals is normal, whether you have a short circuit or an intact one. Instead, try picking up a circuit breaker and, ideally, connect a light bulb in parallel with the breaker. When the short is present, the breaker will trip and the light bulb will turn on. If you've disconnected the part of the circuit with the short, the bulb will stay off.
This CB will fit in place of the ATO blade fuse: https://www.oreillyauto.com/detail/...ircuit-breaker/lit3/ucb15bp?q=circuit+breaker
I tried the search function but not luck
Anyone running a Wasatch Overland Panel?
Is it any good or Im better off with a DeltaVS QPM?
You will need to provide your own backboard for mounting equipment. That or you will be limited to how/where you mount equipment.
