Not all this weekend but a busy couple months working on the 80.
Finally finished installing the sound dampening and new carpet:
Finished it off with Huracan tailgate storage lid, love it:
and new rear quarter belt molding and d-pillar ducts/vents
:bounce:
What's the part number for the belt molding? I order for the four doors and thought I was getting black but they are chrome... so I'll have to paint those black as I hate chrome. So I'd like to order the black ones for the rear quarters... Thanks!
75670-60020
75660-60020
I spent a few hours today addressing the previous owners stupid body lift. A couple of years ago I was being an idiot and drove way to fast over some rocks that were way to big and it ended up cracking the body where one of the previous owners home brew aluminium body lift pucks made contact with the body. I welded the cracks and reinforced the body where it cracked and I figured the others would be good as long as I didn't abuse the rig by driving 30mph over a bunch of 1 foot+ boulders...
Well about a month ago after a rotate and balance I took off down a dirt road I had driven many times. The road was in poor disrepair and had not been grated for awhile. At first I assumed the extra rough ride was due to all the pot holes and washboard but after a few miles the road and ride got even worse and the rig developed a new noise from the rear of the truck. At this point I could tell something was wrong because the ride was so terrible. I decided to air down my tires and when I put my air gauge on the tire I realized that the tire shop must have aired my tires up to 80 psi.... :bang::mad::mad::mad: I guess driving 50+ on the beat up road with 80 psi in my tires stressed the body enough to cause new cracks at another body mount location. This time the body cracked at the rear most mount location on the drivers side.
This time I decided to replace all the stupid aluminium blocks with something wider because the aluminium blocks were only 1.9"' inches in diameter and I am hoping that wider blocks will prevent this issue from reoccurring until I can just remove the entire stupid body lift in another year or two and redo the entire suspension. I found this guy online that will make custom body lift blocks so I went ahead and ordered a set. Mikellis body lifts The blocks seem great and are just what I wanted. I was able to weld the cracks and reinforce the area with extra metal again and get the two rear most blocks swapped. If anyone does want to pursue a body lift I would seriously consider ordering pucks from this website and sourcing your own hardware.
View attachment 2332972View attachment 2332970
I also wanted to do the second set of blocks from the rear tonight, after looking at a schematic I could see that this set appears to be the only body mount that is not through bolted, rather I assume that these mounts bolt into a captured nut because I could not find a way to access the top side of the bolt. Well of course not only was the previous owner stupid enough to use aluminium blocks with a 1.9 inch diameter in direct contact with the steel body, but he also decided to use SAE hardware for the body lift. I guess he was also stupid enough to put SAE bolts into the 2nd set of body mounts from the rear.
I tried to remove these bolts but to my dismay they are just spinning both directions without coming loose or tightening. I am assuming that the previous owner cross threaded the SAE bolts into the original Toyota captured nuts and when I tried to break them loose I only managed to spin the captured nuts. I have pulled the carpet up along with the interior trim and I cannot see a way to access the other side of the bolt. I am thinking at this point I will have to use a hole saw on the rear floor to get access to them.... What a nightmare, I can't believe the previous owner was stupid enough to use an SAE bolt in the OEM captured nut.
If anyone is considering a body lift I would recommend keeping it at an inch or lower and using blocks that are as wide as possible and not aluminium. I have put a lot of offroad miles on the previous owners set up and both the times I have had problems my driving was as much to blame as the body lift. I still beleieve 90% of 80 series owners would be fine running a body lift, especially if the lift is done right.
It would seem that you have 12 body pucks rather then the normal 10. My OEM body did not have bolts there nor did I install any body pucks in that location.
nice rig, i am always cautious when it comes to mounting too many accessories in front of the radiator resulting in air flow restriction.
Thanks, that’s a temporary location for the winch control box until the turbo is in and I know what kind of room I have to work with under the hood.
That being said, I have yet to see a temp over 190 for the last 6 months/2k miles since the rebuild was completed. 192 used to be normal but these days it pretty much just sits a 184 :grinpimp:
Yeah, I just counted the 12 aluminum pucks the previous owner put on the rig and order 12 replacements. I have decided to only swap the ten and leave the other two alone. I tried to hold the two others with pliers and remove the bolt but the bolt still spun while the aluminum puck and rubber stayed still. So apparently the previous owner figured out a way to thread an SAE bolts through the holes in the crossmember, through his lift puck and the rubber dampener and into the OE threads in the body. I am only changing them to prevent the body from cracking again and I hope to remove the body lift completely in another year or two. So I will just leave those two alone for now seeing as how they have rubber against the body instead of aluminum. So far I have finished swapping all the others except for the two front ones without any other problems or cracks discovered.
Just refreshed OEM bumpers and upgraded to 33s on the HDJ80
That was me too until the turbo on hot days. Now see 200-202 pretty often when its 80+ outside and i have the A/C on.
Time to do a fan hub mod. Or just a ron davis :worms:
Since the first time I had to disconnect the battery on my LX, my battery terminal have been giving me a headache.
PO clearly went the lazy route.
So I ordered some supplies and went to work.
I was gonna do the positive side as well, but the eyelet size on my winch, main and fusible link positive lugs were too small to fit on the new terminals. So this time I went with the lazy route and decided that this gonna be another day's project.
Modified fan clutch made a huge difference for me, definitely worth it. Replacing the entire cooling system definitely takes the cake though :grinpimp:
I lusted over a Ron Davis but pretty much spared no expense with the rest of the rebuild and couldn’t quite justify it over a new OEM rad for the price difference, which I had no prior issues with.
...but man, that RD rad is a piece of art. There’s always next time.
With ya. I replaced every part in my cooling system when i rebuilt 20k ago, but didn't upgrade the fluid when i threw a new blue hub in. Thinking that'll take care of it.
May throw an aux fan up front too for the slower stuff.
Cracked panhard bracket repaired. This 80 is on stock tires with no relevant lift or wheeling that I'm aware of in it's life. It did have a front-end impact in the past that may have caused this. Couldn't find any other cracking around the steering box mounts, etc. I'll be keeping a closer eye on this spot in coming years and think it's a good spot to check periodically on any 80.
Resurrecting forgotten projects but now I get to do them without a driveway or floor jack since we moved...lots of hard pack dirt though. :yuck:
Today I bought a Redhead steering gearbox, paint for my Marlin HD tie rods and supplies to power bleed the brakes once the caliper overhaul is complete. Oh yeah, Banana's on Parade :banana: :banana: :banana:
Just need to get dig out my OEM jack, @LandCruiserPhil's jack adapter and some plywood for the creeper and I'm set. Not happy...but set. :confused:
The driveshaft needed some love. I had pulled the front and rear shaft last weekend to clean and grease them. I could tell one of the u-joints on the rear shaft was going bad and would need to be replaced soon. I put it all back together and drove it this week. Well, that u-joint went out on Thursday morning. You can see the cap that had been pumped full of grease 4 days before. The needle bearings fell out in pieces.
Any details on how you did that?
You can modify your existing grill, but I chose to get a donor grill and modify that so I can go back to my other one if I wanted to. You obviously need to cut out the center portion. It's going to leave some voids that need to be fixed. You can use fiberglass, expoxy etc to fill the voids and reshape the inside of the grill. I used a skim coat of bondo to finish it off before paint. Choose whatever mesh you want. Metal meshes can be bent/shaped if they are thin and can be attached with screws etc to the grill surround. I used a honeycomb grill that is ABS plastic. Had to cut it to the right shape which takes a bit of time to get the fit right where you want it. I expoxied the mesh in place and then just attached the OEM emblem. The emblem I used is one for an FJ Cruiser.
Slee installed a prototype battery/redarc/dual compressor mount, Jackson/Brian and the crew did a great job getting me sorted.
Also got a replacement rear bumper on, regeared to 5.29s, added lockers, cdl switch, and fixed some of my carelessness! The rig is feeling sooo good with the gears.
Thanks for the awesome work @sleeoffroad ...but not for breaking the bank 😉
