What Did You Do With Your 120 Today? (13 Viewers)
Easy, most likely blocked...just blow them out with air. I have had to do that every year.
That's hopefully all it takes! I am used to fixing LR3's that the drain connections have disintegrated and you have to take apart most of the interior to get to them. Then again I did buy a Toyota product for a reason! :cheers:
Compressed air...done. I use a spray attachment and my co2
Locked down my dog's bed with Velcro & snaps on to the draw I made, sits the same Hight as the seat folded over
Painting new RCI sliders
Well my wetness issue does not seem to be a sunroof drain as they were surprisingly clear. Looks like water is trailing down the inside of the glass on the back door after a rain today. I pulled the door gasket and it was packed full of clay/mud on the bottom and was retaining water bad enough to start rusting the body seam. I am not confident this is 100% the issue but it's a start.
Loaded it to go camping today and tomorrow do two trails I have wanted to do for about a Decade. My previous 06 DC Tundra was too big to do the trail. I hope the 120 fits through the entrance. It's open one month out of the year. They have two big boulders to squeeze between while turning. I nearly dented the rear door on my Tundra trying to fit 10 years ago. Now I got sliders to protect that body and a much shorter wheelbase. Wish me luck.
Installed a uhf/vhf ham radio. That is just the face plate in the console. The actual radio is under the driver's seat. I used a comet "no holes" bolt on mount for the antenna. I have a HF to put in there also but I'm not sure if I want to put on another antenna (especially a hf one).
Confirmed the leak is definitely from the weatherstrip door seal. My wife drenched the truck with the hose while I was in the back, I could see where the water flows down the inside of the weatherstrip and pools in the back corner of the truck (where the carpet was wet). I am contemplating trying to clean out the weatherstrip and use 3M adhesive to attach it or buy a new one and 3M that one. Mine is pretty nasty on that inside of the lip.
I use a magnetic antenna for the CB since I mostly use HAM and I can use CB if I really have to go back to the stone ages. But still need to get everything set up on this new rig.
Nice install on the inside.
Your antenna is too low and you are going to lose range big time. Conskder a good magmount on roof.
Did some basic maintenance on my 08 this weekend. 1st oil change since buying it, about 1k overdue (all hwy miles, so I wasnt too worried). Realized after dropping the skidplate bolts that i needed another inch or two of clearance, had to find some 2x8s to drive up on. dropped pan, dropped oil drain plug, and then started cursing whoever the neanderthal was that must have used an impact gun to put the oil filter on. Took 30 mins of jerking around with large channel locks to get it removed.
Replaced wiper blades with some new Toyota oem blades. Can see clearly again...
Replaced Gas cap with new OEM. Got sick of the Christmas tree.
@co4wheel Don't forget the pics! Have a safe trip :)
I did not make it. Forrest Service closed the access path on the west side. Boulder slide blocked the road. Posted other pictures on the Photos page. I did get Tomichi and Hancock done. I have done Hancock Pass a lot. That was no big deal. Great wildlife yesterday. Moose and Deer.
