What are your coolant temps?
thanks greentruck, I just orderd the ultragauge obdII. That should be fun. I'm pretty sure the thermostat is not acting as it should. There is a little flow evident in the radiator, but it sure doesn't seem like enough.
And I'm pretty sure the valve cover shouldn't be sooooo hot to the touch. My other sixes never get that hot. I might do the temp mod anyway when I tear out the dash to replace the heater core next.
Original cooling system... Stays right around 186. It did climb up to 205 last spring going up Vail Pass in 70 degree weather.
My question is, should you be able to touch the valve cover
when it's running, or would it be too hot to keep your hand on, at
normal operating temperatures? Seems like it's running hot if you
can't touch it.
thanks
Meat starts to cook as low as 105 degrees (stewing at low temp), and is safe from bacteria to eat at 165 degrees. Water scalds (cooks) skin at as low as 125 degrees (set your water heater to not have accidents with your babies). So no, you should not be able to put your hand on the valve cover at normal operating temp and leave it there. If you have special skin that resists 180 degree temps, then you may be able to leave your hand on a running engine.
Beautifully stated Flank!
Eggactly.
... I'm pretty sure the thermostat is not acting as it should. There is a little flow evident in the radiator, but it sure doesn't seem like enough.
Hard to say? The thermostat acts on load, cooling need. It is possible/likely that when you are checking it, there is little load, so little/no cooling flow is needed.
And I'm pretty sure the valve cover shouldn't be sooooo hot to the touch. My other sixes never get that hot. ...
Define "other sixes"? If you are referring to older F motors, they are a different bred, circulate little oil to the head. The 1FZ much more aggressively circulates oil, especially to the head, uses it as a coolant to spread the heat throughout the motor. Even temp throughout the motor is a good thing.
Now I'm hungry.
Temps with my new bluetooth gauge hover around 190 in city driving (lots of lights, a few hills and top speeds around 40mph).
Mine stays right around 180. The highest I saw it go was 188. That was during 4LO snow wheeling.
To get back to the Ultra Gauge readings I think an important number to also give is the intake temp rather than what the weatherman says.
For instance today mine had an air intake temp. of 60° and an engine temp of 185°. After sitting at a light for a few miutes and going on the surface streets my intake went up to 68° and the engine temp also went up to 190°.
Last monday I was somewhat surprised while on a trail on a very cool day and cruising along a nice open area at about 15 mph I hit 206°. I was a bit concerned at the time and popped the hood at our stop but seeing that the cut off for AC is at 218° or even higher I am less concerned and will focus in more on my dummy gauge and maybe set an alarm on the UG at 210°.
Should I be concerned, my ultra gauge showed coolant temp. of 210 today, 60 outside temp.,stop and go driving for about 10 miles. When I got home and parked I heard gurgling from the coolant system. I replaced radiator, thermostat, and water pump about 4 months ago (non-oem) I KNOW I KNOW, any suggestions
I did get back up to speed for about 10 mins. and then parked my alarm is set on 210 on my ultra gauge and it went off a couple more times before I parked.
Did some CPR on an old thread and brought this on back from the dead. :) I'm looking for some additional insights as I'm chasing some temp issues. I've been doing LOTS of reading on the topic but could use some thoughts from you guys.
Background on my truck. I purchased it this past December so I've only had it for about 6 months. It's lifted, has an ARB/bumper with a winch, no lights blocking the grill. Snorkel. Currently at 198K miles. The guy I bought the truck from had replaced the OEM radiator a few months before I bought the truck with a Koyo unit he got from Safari LTD (I'm not sure which model Koyo). I don't believe he was having any cooling issues that resulted in the rad replacement, but a cracked tank. After I purchased the truck, I replaced the PHH, t-stat and a few other hoses as PM. I was seeing temps climb into the 212-220 range on long highway climbs, and temps in the 210-215 range on lesser grades but while the truck was under load. Idle temps seemed to be normal and city driving wasn't causing the temps to climb beyond ~200* at most.
I suspected possible HG issues so I had it looked at. There was definitely HG failure, although not a catastrophic one and I replaced the HG a couple months ago. At that time the remainder of the coolant hoses were replaced. I've replaced the OEM fan clutch with a blue hub clutch (did not change the oil in it). I'm still getting similar cooling problems where the temps will rise beyond what I think they should when the truck is under load, mainly at highway speeds. Ambient temps here in SLC have been hot lately (around 100*) but the symptoms aren't just recent. On my highway commute the coolant temps will climb to 215+ pretty regularly if I have the AC on. If I turn the AC off it won't climb as quickly but will still stay hot. I haven't been comfortable just letting it continue to climb, so I almost always open the windows and turn on both heaters once it get's to about 215* and that will usually drop the temps back close to 200* sometimes as low as 194*. The factory temp gauge seems to be staying in the normal position consistently. I'm getting my temp readings from my Ultragauge.
Needless to say, I don't think I should have to be running the heater full blast in 100* ambient temps to keep the truck cool enough to run the AC. I've got a trip coming up in the next few weeks with the family starting at the Grand Canyon and making our way up through central Utah. I know weather will be hot and dry and I'd like to be sure I've got the cooling system in good order before the trip.
I'm looking for advice on next steps. I'm wondering if the Koyo radiator doesn't have the cooling capabilities of the OEM rad, so I'm considering going back to a new OEM radiator. Also looking at replacing the water pump. Possibly the t-stat again just to be sure I've got one that isn't sticking. Am I justified in my concerns? Are there other things I should be looking at? Any advice would be helpful.
Box Rocket, sounds so similar to many 80's.
I'll say I don't think it's the HG at all. Check out Joey's epic thread for all his rigamorl, and ideas on what is going on.
Stock OEM blue fan clutch seems to be pretty whimsy for the southwest climates. Many of us upgrade the silicone fluid in them to 20,000 - 30,000 cst fluid for superior cooling results. Many threads on the subject . John
Possibly air in the system?
I have flushed system, all new hoses, new oem radiator, new heater valve, new thermostat. Green coolant. Stock 1fzfe with arb with warn m12 without lights. I scan gauge usually shows 186 to 193 when driving. Highly dependent on idling time. I have occasionally seen 195 and just once 198 when idling for a while. I get high iat's when idling for a while like 150 deg. I also have a landtank blue hub installed.
I live in southwest ga. So flat without much hills but hot and muggy
based on the above your coolant system is not doing a good enough job at speed.
I have somewhat the opposite problem. While at speed on the freeway the truck cools very well but when I stop I see temps go high. My issue has to do with the clutch / fan / shroud combo.
Your issue must have to do with the cooling capacity and / or airflow at speed. The fact that you turn on your heaters and the temps drop logically points to that. I would look into another radiator. I used an aluminum unit from ebay that has worked well, it is larger than stock. It was not exactly bolt in so consider that. A good coolant flush and using the store acid block cleaner is a good idea as well. You should be able to drain the block as well, if you can't that means that there is alot of built up gunk in there and the passages are shut.
To the OP, I think your temps are fine mate relax about the temps. I see you are no stranger and have already have been exposed to a forum, and it has to be assumed you can see that a lot of the posts have genuine and valid points but you also have to sift through the BS as well.
Brian894x4 raises a valid point, he said 'if you have all new OEM components then the system should read 181', I doubt that particular temperature could be cast in stone Brian, as Flank pointed out there are too many variables but, your running temps should be within the manufacturers specification and this seems to be where the confusion lies.
The manufacturers specification for any engine is the ONLY true guide, so let us get this all into to perspective.
You need to use a number of specifications to tell you what is the normal operating temperature of any given engine, lets us look at the thermostat, now guys bear with me here as I have a diesel but the principles remain the same, my engine creates heat and it needs to be controlled just as a petrol engine does.
So my figures are for MY engine.
My thermostat should START to open at 165 - 172 F (variable) but be FULLY open by 194 F, note there is NO variable allowed here at FULLY OPEN. There was a mention that the thermostat is not designed to control engine temperature but is simply there to get the engine up to temperature quickly (and of course gives us a heater). I do not totally agree with that statement, I would argue that the above range indicated is where the manufacture would like the engine temperature to be kept under NORMAL conditions. If this was not the case why use a variable thermostat, why not simply have snap open/snap shut valve at 'X' temperature?
The A/C switch cut out is shown as 226 F, this IMO is the maximum operating temperature where you are exceeding the boundaries of the standard system.
Toyota states quite clearly that THEY believe a coolant temperature of 230 - 248 F is too high, again note the variable, this means the A/C cut out is only just below the POTENTIAL overheating point, that is when the pressure cap opens and you start to vent coolant into the expansion tank, you are in effect starting the overheating process, any loss of coolant to the expansion tank is a loss of available coolant to the engine, so the temperature rises ad infinitum.
So we have a normal running temperature 'RANGE' variable of 165 to 194, this would put Brian's figure of 181 F very close to the 179.5 F that would be the middle of the range of the thermostat at it's minimum open temperature. Now take the upper scale of the minimum opening temperature and note the 'middle is 183 F, a bit of a coincidence to Brian's figures? IMO this make sense, the thermostat not continually opening and closing as a snap open/snap shut valve would have to do to maintain that acceptable operating range temperature, it just so happens to be damn near the middle and can gently open and close according to the environment/workload.
Now note the disparaging gap between the thermostat operating range, and the actual engine operating temperature, if the coolant moving through the block and head of an engine working hard for example a steep hill perhaps A/C on, the engine is hot, the coolant is hot, the thermostat has just reached it's maximum opening point of 194 F, the very fact that the thermostat is fully open tells us the coolant is at 194 F, but wait a moment......the coolant has only just left the cooling medium i.e. the radiator, which means the temperature at the TOP of the engine is way above this figure 194 F, perhaps 25+ F and if the load increases then it is about to get hotter, I cannot give a definitive answer to how much hotter, and the 25+ F is speculation but cannot be far from the real world figure of a working engine, add the 194 max of the thermostat to my speculated 25 F degree rise through the block/head now gives a figure of 219 F, now weigh that against the A/C cut off temp of 226 F means you only have around 7 degrees to play with?
I will just throw something else in here whilst I am at it, I work with OBD pretty much every day of the week and have some pretty good gear, OBD sensors can be two or three degree's/volts/OHM's or more off and still have no distinct affect on the engine fuelling but they may well show on the scangauge, so if two apparently perfectly running cars show slightly different scangauge readings, as per Flank I would not be reaching for the tool box.
A shot in the dark here but, I am going to say that most 80 owners (including myself) purchased our cars second or even third, forth and perhaps even further down the resell list? It then follows that a lot of vehicles are running around with non OEM parts (remember Brian's comments'), also as many if not more have seen wrenching by less than professional mechanics. This combination makes fault finding very difficult, in particular if you have only just purchased the car or, perhaps you purchased it in the winter and when summer comes around you find you have problems.
I often see the phrase I have 'base lined' the engine cooling system, only to see the same poster having a problem a few months later, it then turns out it has aftermarket this and aftermarket that parts fitted, and then he or she is chasing their tail trying to find the problem with the engine running hot. Or you will see advice as water pump, fan clutch, thermostat but, you never hear someone say 'remove the cylinder head and remove 20 years of rust/calcium/lumps of instant gasket/ the old rusty freeze plug jammed between two cylinders oh and don't forget to take out that old nut and bolt while your in there'! I have been around engines for more years than I care to remember, but that is what I have actually seen cause overheating issues. I also see so much BS and generalisation with no real evidence that just adds to the confusion.
I am doing a lot of testing on my own (diesel) engine with the VC cooling fan removed and an all electric system fitted. Facts again dictate thus far that this is working as good and in some cases better than a VC or mechanical fan but, I would concede that unless the system is specced very carefully with some redundancy built in as mine has, then it may not have the reliability of the mechanical fan but, I reckon once the trials are complete it may well outperform mechanical fan in the environment that I use the car in, a bold statement? Check out the link in my sig and see not speculation but instead, repeatable facts and figures.
regards
Dave
mine stays around 195-205 in this weather down in NC... been consistently > 100... it's in the 90s now and it usually hovers around 200, if i'm running down the highway it stays below 200, in the 190s...
it doesn't seem as if my cooling system is in quite tip top shape, but it seems pretty consistent, this is with non-modified new blue clutch, a 5 year old koyo and a shortbus with a 9500lb winch with cover that seemed to have made a noticable difference in cooling :/
