Vehicle Lifts: 2-post, 4-post, etc (1 Viewer)
Apologies if this is a repost as I recall some discussion on pogo stick supports earlier in this thread. I bought this one a few days ago and can totally endorse its quality, especially for the price, if you need one. And anyone that has a 2 post lift needs at least one if not two of these.
I have the version with foot pedal, it’s only more handy in some situations, not often.
I looked at that one but decided to keep it simple. That would be handy though in a spot where you can't turn the adjusting handle.
Apologies if this is a repost as I recall some discussion on pogo stick supports earlier in this thread. [SNIP] And anyone that has a 2 post lift needs at least one if not two of these.
The two things to remember are to use them and to remove them before lowering the lift...
Make yourself a reminder sign.
I use magnets to keep them in place, covering the motor actuator button.
Told myself I wouldn't do it - but I did. Lowered car down on an oil drain tank. Barely made a noise but I heard it and stopped. Bad thing is I probably looked right at it walking up to lower lift. Cheap HF tank so was able to straighten fairly easily.
Yep. You're likely going to do it at least once - and hopefully that once is enough!
@Waorani I have that same oil tank. The first time I had drained it I pumped the air up to about 40lbs and opened the valve,,,,BIG MISTAKE.
Cleaned up oil for 2 hours.. it only needs a few psi and it flows easily
I did the same thing. Fortunately oil didn't make it to the ceiling! After that I added a relief valve to dump pressure fast. Also don't like the little regulator on it and rigged up a separate hose/regulator to more easily control pressure. You're right - only a few psi is all you need.
Yeah... Those things can go wrong quickly... VERY quickly...
OH MY! A gusher. I can smell the used oils from here….yuk!!
Not to mention hearing the profanity (#&$(*&&!!!!) changing over to entreaties to one's sacred figures (Oh sweet baby jeebus! Please let it stop!) to quiet sobbing... :rofl:
Gotta have the pan all the way up and big valve closed. Would be nice if there was a valve in the tube connected directly to pan. Wouldn't stop all leakage but maybe not as catastrophic. A relief valve on the tank is also a big help so you can dump excess pressure fast.
You guys know if that’s covered by homeowners insurance? I can’t see even the start of a cleanup and the greasy feel on everything a month later
Yep…that epoxy floor surprised me on the first cleanup…was a minor spill when an 3/4 empty oil bottle slipped out of my hand so it spilled maybe 1/2 cup. After wiping it up I poured a little acetone on a towel and no trace of oil or slippery residue remained… my go to routine if that happens.
