Ultimate OEM 60 series parts still in stock (3 Viewers)
Great news! The fake, Chinese, and non-refillable “OEM” wiper blade assembly, 85212-YZZ10-TM, which superseded the original NWB blades for the 60 series and 1991-1993 80 series with screw type hook, as well as what Toyota lists for several other cars such as Cressida, V20 Camry, E90 Corolla, has been discontinued!
Why is this good news? Because nobody should’ve been buying it in the first place. They are crap. The true, factory original blades lives on overseas as 85220-16640. Can be used on the LH and RH side. Still made and available on Amayama, Partsouq, etc, and can be refilled by cutting 85214-24H90 or buying 85214-12H90 overseas. Hopefully Toyota USA brings this part back to the USA now that the MVP sightline version is dead. They have for a few other older wipers.
a good method starting place is to look up a JPP same in kind model Toyota you have
so , 1994
VZN110 All SR5 Pickups 88-95 1/5 were made in JAPAN so use microfiche code JPP , all DX and Base Models are NAP
we now have the full wiper blades now that will lead us down the Made in Japan rabbit hole.
85220BLADE ASSY, WINDSHIELD WIPER
85212-35020RH1
85222-35070LH
- both these part numbers supersede to another made in Japan blade ......
- 85222-60061
- 85212-35021
- you will know you received real deal Japan. spec. parts wiper blades , because ALL still come in the very very Retro late 1980's - present day sealed blister packs w/ red , white and black color cardboard under the clear blister pack stuff like you see below :
i think i am going big with the OEM DENSO DDS ones below ...
i want to feel the Power ...:D
so , 1994
85212-35020RH1
85222-35070LH
- 85222-60061
- 85212-35021
Some of the factory blades do come in normal plastic or cardboard boxes. 85222-60061 comes in plastic. It’s identical to the 35021 blade and on the 5th gen Trucks, the LH and RH are the same length.
Fuel hose 90445-22002. Looks like it just got discontinued.
Anybody know if 100% gone or superseded?
Can anyone with access check if 85220-16640 has come back to the United States? The factory wiper blades? Still available outside of NA so hopefully comes back to the States.
