Ultimate OEM 4X SERIES PARTS IN STOCK
PNs as promised (for 1982 FJ40):
04111-61044 engine gasket kit
90116-10299 exhaust manifold stud (to downpipe) + 90917-61044 gasket
83320-60051 fuel sender
46410-60130 ebrake cable
12101-61013 oil pan + 90341-12012 plug + 12151-61011 gasket (FJ60 pan with smaller plug due to parts consolidation)
99343-11570-77 PS belt
99343-11265-77 Fan belt
04481-60020 leaf spring shackle kit
42311-60053 RR Full Float axle shaft
I check for the availability of the two short hard lines on the PS pump: NLA
Bill
Nothing like getting some new stuff! Tail lights, batter tray, battery hold down.
Just got hit with my first 'consolidation' part last week. Installed new manifold studs from stock on @SW20 's cylinder head. The replacements from Mr. T are longer, and have an unthreaded tip like the 08042 carburetor studs.
Since Mr. T only thinks of these as being used for the two center positions, I can see where they wouldn't see the problem. But since I routinely change out all the manifold bolts for studs (less likelihood of stripped/cross-threaded holes in the cylinder head) this complicates installs in engine bays with tight clearances.
16381-60081 alternator bracket mount. Fits 1958-1975 F motors
96431-53828 block drain plug cock assembly. fits 1958-1993
A few odds and ends related to the windshield washer. There are several segment of washer hoses. The segments under the hood are larger in diameter than the one running through the glove compartment. The thinner one is harder to find:
Here are some connectors that let you transition from a larger diameter hose to the smaller diameter hose:
Here is the other type of connector, found under the hood, which lets you connect 2 hoses of equal diameter (both are of the larger diameter type):
The reason I'm showing these part numbers is because when you look in the parts catalog, it's difficult to tell from the drawing what's the difference between these connectors.
Nice. The first part is still available from Toyota in the US market since it is a generic part applicable to many vehicles over the years.
Internal air cleaner gaskets (top and bottom) for 69 - 75 F engines and 78 - 80 B engines.
BJ42 1983
Radiator
Heater control valve under hood and center console heater
Marker lights front and rear
Tailight housing and lenses. (aftermarket units s***ting the bed after five years)
Front blinker assemblies(aftermarkets are crap)
Glow controler.
Weird stuff but I want the factory stuff..
BJ42 1983
Radiator
Glow controler.
Heater control valve is still available new OEM.
24v Rob?
24v Rob?
Yeppers, good old trusty 24 volt system....far far superior to those lesser 12 volt systems....;)
Onur the lights for the rig can all be 12 volt units, just need to run 24volt bulbs..
Sadly the plastic vents on the roof are no longer available along with that nice front floor mats, I think Land Pimp (John) purchased the last one ten years ago, he claimed the rubber to be thicker.:beer:
Are the inner and outer (lower and upper?) transfer case boots for an '83 40 the same as a 60 series or just singular freaks?
