- Thread starter
- #21
What is usually the root cause for this event?
Change all coil packs to OEM/Denso
Starting to wonder if I even need an insert.I don't see anything bad in your borescope pics very minor nicks on top of the piston and I have seen worse case just go with an insert and call it good save the money for other things like others have said if the current shop don't want to do it find some one that will and install OE parts or Denso coils. Thanks for sharing that borescope I think I will buy one for myself.
Well, he just re-used my new coils packs and plugs I had just installed weeks prior. He had a LC engine with all new components installed. New rod bearings, piston rings, new head gasket, new valves, seals, o rings, list goes on. New WP/TB as well. This was like 2 months ago.That’s extremely low. Used long block? When was this? New coils alone are 1k.
Would you mind sharing the name of the shop? And is the engine VVTI or non-VVTI? Thanks!Well, he just re-used my new coils packs and plugs I had just installed weeks prior. He had a LC engine with all new components installed. New rod bearings, piston rings, new head gasket, new valves, seals, o rings, list goes on. New WP/TB as well. This was like 2 months ago.
If I could actually screw a plug in and drive it, How to address the issue of the electrode that is somewhere above the valves? Bore scope images clearly show that something (missing electrode on plug) was in there and left a few marks, although I got lucky.
Is there a way to look inside the head?
Thanks a lot! I may need to get a swap done at some pointTommy @ TJ Auto in Garden Grove. I have an '02, so non-VVTI.
He's my official go-to for everything now for my LX. Very fair pricing and trustworthy work.
Yeah I guess I noticed the sound but thought it was the manifold leak getting worse. Thanks a bunch. I’m talking with a few local shops now.IF you're worried I would see if you can get a better look at the exhaust valve before pulling the head. To do time-sert right and ensure you dont get any debris into the cylinder when cutting the new threads, removing the head is good practice- but not necessary- you have to be super diligent to get any shavings out of the top of the cylinder. I'd prob install a time-sert, do a compression test and drive it ( I wouldn't trust the threads after this event).
The blown spark plugs dont happen all of a sudden, they have a warning period- but you have to pay attention, listen and be familiar with your engine sounds to know the difference in the ticking sounds of injector noise, fuel pulsation damper and a leaking spark plug. Re-checking plug torque at 30k intervals is good preventive practice.
!! Read the Spark Plugs Alert thread linked above to know more about this, its a fairly common issue as our trucks rise in mileage. I think we're seeing a new post on this about once a month.
