scottm
- Thread starter
- #201
Been a while, but I think disconnecting the hose at the top was necessary, and lowering that hose was a simple way to drain the coolant as low as needed for the water pump replacement.Are you saying it is better to disconnect the hose down by the oil filter and drain?
Or are you saying drain this hose (as shown) before you remove thermostat?
Will I end up removing the oil filter housing? Wondering if I need to plan on an oil and filter change, also wondering if I need to replace some o-rings by the oil filter housing?
I believe the oil filter had to come out, to get a fan bracket bolt out. Perhaps could be done without removing the filter, but I chose to remove the filter.
