I just installed a Continental kit that I got from Rock auto. The bearings were Koyo and belt was Continental. Not sure where the water pump came from. Time will tell, I guess.BUMPing this very helpful thread to ask if the Amazon AISIN kit is still the recommended parts kit for this PM? Some more recent reviews on Amazon are mixed.
My hunch is there's a noticable price difference between the AISIN kit and Toyota parts from Partsouq...
Not necessarily the “Amazon kit”, but the Aisin TKT-021 kit is what is recommended. Whether you get that from Amazon, RockAuto, Yotashop, or Napa is up to you.BUMPing this very helpful thread to ask if the Amazon AISIN kit is still the recommended parts kit for this PM? Some more recent reviews on Amazon are mixed.
Correct.I read the pictures on page 1, but I do not think he showed pics of replacing the front main seal?
Screw a wood screw in it a few threads, then pull with pliers. Install with a PVC coupler or nipple.I read the pictures on page 1, but I do not think he showed pics of replacing the front main seal?
Getting ready to do this job...
If factory seals aren't leaking, I'd do not touch them. I've yet to see crank or cam seals leaking or even weeping, unless they've been replaced or "HIGH Mileage Oil (very damaging to seals)" used. If leak does develop over next 90K, it will be very minor. It can always be replaced next T-belt job.
The most common leak I find, is tensioner pulley bolt (No. 1 timing belt idler). Which goes into oil pump housing. Only because last T-belt job, threads were not sealed with sealant. I typically use Toyota FIPG 102 or 103 0il, but any oil rate thread sealant will work. Just don't use a permanent one like red loctite.
Oil pump housing, idler pulley assembly bolt hole weep.
You'll for sure find pitting on the block under water pump gasket. Do not file on block as shown in thread. Use wire brush, green scratch pad, etc. and degreasers. Getting gasket mating surface and pits cleaned out. Then fill pits with FIPG 1282B, scrape flush to block, let cure before assemble.
BTW: The lower fan bracket bolt that goes through AC compressor, made easy.
Make sure to put the little cover spacer & gasket back on, after water pump installed and before fan bracket install.
I find this clip busted from previous service very often.
It could be the seal, but typically it's not. Once sprocket off, inspect seal to crank surface area.Th
This is very helpful.
I have some buildup down by the crank and so I thought it was my front seal…
Few more tips:
1) Make sure to tuck in the oil sending unit and crank sensor wires, before installing fan bracket.
2) Replace fan bracket if any doubt as to condition: i.e oil on back of seal in rear, any side to side play or any sound when spun.
3) Replace drive belt tensioner, if tension on drive belt is weak.
Hey, thank you!More BTWs:
Note that lower timing belt bolts are shorter than others.
Inspect the Aisin kit closely. I've had ~2 out of 5 with shipping damage. Most often found damage issue with them are:
1) Water pump water crossover pipe hole damage (out of round).
2) Water pump gasket damage (break or damage in/on rubber seal).
3) Damage to large or small O-ring.
I like R&R spark plugs and heater Tees with each T-belt job. Keeps them on schedule. Also, having plugs out during final belt timing mark inspection (720 degree turn), it's just that much easier to turn the crank by hand (wrench).But crank, can certainly be turned with plugs in.
If any doubt as to front water bypass (pitting) or it's gaskets, sealing it to either head. Now is a great time to replace. Replace throttle body gasket also, if you pull it!
I keep most all parts that could be needed during t-belt job in stock. So if you can't get whatever you may need timely, hit me up.
The most common leak I find, is tensioner pulley bolt (No. 1 timing belt idler). Which goes into oil pump housing. Only because last T-belt job, threads were not sealed with sealant. I typically use Toyota FIPG 102 or 103 0il, but any oil rated thread sealant will work. Just don't use a permanent one like red loctite.
Random question - when I replaced the spark plugs last summer, the clips that held the wiring basically disintegrated. Do you know what p/n these are, and how many I need?I like R&R spark plugs and heater Tees with each T-belt job...
You can inspect the clip now. If wire housing is held on t-cover you're good. If you do break, it can easily be install after the job is done at anytime.Hey, thank you!
I am going to order up one of those clips you mention, chances are that mine is missing, or busted, or I will bust mine!
I am also going to order up some of those bypass pipe gaskets that we talked about back when I replaced my starter. They had 2 in stock, so I got those for the rear pipe, now I will get 2 more to do the front pipe.
I did the heater Ts with the starter last month, so those are new. I did plugs last summer, so those are relatively new. But I will pull them to make it easier to turn the engine over.
Thanks for all the help folks!
Not really. I'd say ~9 out of 10 are there.Is it your experience that the spacer and gasket are usually missing as well?
Not sure what clips you asking about. Do you mean the coils' wire housing? No I don't. Or some of the clips holding wires along their path? Some we've tried to get and never found. Like the one holding wires on top just before wires drop down front of left (drive side) timing cover. These I just use ties.Random question - when I replaced the spark plugs last summer, the clips that held the wiring basically disintegrated. Do you know what p/n these are, and how many I need?
I am striking out searching through PartSouq
Thank you!
I am referring to the clips that hold the wires running to the coil packs along their path. Mine looked like this after they came apart:You can inspect the clip now. If wire housing is held on t-cover you're good. If you do break, it can easily be install after the job is done at anytime.
I'd leave the spark plugs alone if newer, other than check the torque, which I use 18 ft-lbf. I say this because, the crush washer does not work as well the second time as is already crushed. Crank is only a little harder to turn, no big deal!
For wire housings. I always just get from my local Toyota parts guy (25 yrs same location). He's really good at finding the small stuff. Which he's said, I order more small parts than anyone ever...LOL If he can't find on 100 series parts diagram, sometimes other Toyota's have the same and he finds. Others times I scavenge, from used harness I've around.
Are you saying it is better to disconnect the hose down by the oil filter and drain?There’s a rubber and steel tube running from the oil filter housing to the intake. If you unhook it from the intake and swivel it down into your catch bucket, you can drain the coolant from the block. You can see I pulled the thermostat housing first and there’s coolant all over the engine. The coolant visible in the rectangular intake for the waterpump is no longer visible after draining. Pull the thermostat housing after draining the block using this hose, opposite of what I did. Perhaps there’s an easier way to drain the block, but this seems to work and you have to pull that hose anyway.
View attachment 465388View attachment 465389View attachment 465390
Yeah that is one I never found. I Zip tie them often.I am referring to the clips that hold the wires running to the coil packs along their path. Mine looked like this after they came apart:
Understood about asking the local counter guy, or just using zip ties.
Thanks!
No need to remove oil filter housing or oil filter, just oil cooler pipe with hoses. The exception is oil sensor unit, if using chain wrench to hold harmonic balancer (crank pulley).Are you saying it is better to disconnect the hose down by the oil filter and drain?
Or are you saying drain this hose (as shown) before you remove thermostat?
Will I end up removing the oil filter housing? Wondering if I need to plan on an oil and filter change, also wondering if I need to replace some o-rings by the oil filter housing?
