Blastservices
- Thread starter
- #61
Mule = carrying something from south AMERICAWhat is the deal with that tank???
That is my guess…zero reason to completely access the inside.
Are you going to cut it open?Mule = carrying something from south AMERICA
He quit communicating with me so I welded as much as I could and then did a tank liner. It still leaking around the sender hole so I pressed on and got another user (Eric Ellis, which I want to thank again… Thank you Eric!) to send me one. I just got it but it needs to be cleaned up and I need to figure out where the vent holes lead to. I’ve got the original in the truck and am sorting out lots of other stuff and will pull it and swap in the near future.Are you going to cut it open?
Have you gotten your replacement tank from Cali?
I think there was a graphic someone posted that showed about 6 different part numbers for fuel tanks maybe even in the early years of the 55.
It wasn’t from Spector… it was a grid with factory parts numbers and year break downs. But it equally explains it I guess.This thread is a good resource for Pig fuel tanks:
anybody ever put an fj40 fuel tank in an fj55?
forum.ih8mud.com
Looks like you had been in there a little while ago. That is when I first saw your Pig!
Here is the graphic you may have been thinking of:
Maybe; I don't remember.Might have been @WarDamnEagle , he is good at posting year ranges...
77100 | TANK ASSY, FUEL | ||
77100-60080 | (08/1976 - 08/1977) | 1 | |
77100-60081 | (09/1977 - 12/1978) | 1 | |
77100-90363 | (02/1973 - 04/1976) | 1 | |
77100-90371 | (05/1976 - 07/1976) |
Darn, 3 different tanks for 1976???Maybe; I don't remember.
Here's 1973 through 1978. Easy enough to do it for other years if you need the information @Blastservices
77100 TANK ASSY, FUEL 77100-60080 (08/1976 - 08/1977) 1 77100-60081 (09/1977 - 12/1978) 1 77100-90363 (02/1973 - 04/1976) 1 77100-90371 (05/1976 - 07/1976)
Yes I can.Darn, 3 different tanks for 1976???
This is a bit more info than SOR posted.
Thanks @WarDamnEagle ! Would you be able to run for all the years and then post in here: anybody ever put an fj40 fuel tank in an fj55? - https://forum.ih8mud.com/threads/anybody-ever-put-an-fj40-fuel-tank-in-an-fj55.1247738/page-2
Pabst Blue Ribbon in the long neck bottle just a hair above freezing is the best field refresher ever made...Pabst isn't a bad beer at all, but that Coors Light.....
South American spec? Not sure what’s happening there. They never had plating on them though. Kinda different!I noticed your license plate lamp covers aren't chrome. Future project or leaving them black? Just curious.
Sounds like a great learning curve when you are the new guy!At AB we would fill the bottles at 32 degrees in order to keep the foaming down, but man was that good. Filler beer or "green beer" as they called it was before the pasteurisering and still had the live yeast bacteria in the beer which gave it a great taste. Only drawback was your system had to get used to the bacteria, if you know what I mean.![]()
