Got any videos of this beast running and driving?
How is your heater working? I noticed mine takes forever to heat up and seems to never be as warm as the gasser. Have not tried the heat on the hwy. The temp sensor seems to hardly even get hot enough to get past about an 1/8 way up the gauge
I am using the 60 sensors and both heaters. Also a new 60 radiator. It's crazy cold her right now, has not been over 40 since I got the rig back on the road last sat. Most days have been barely above freezing and we have had snow on the ground since Monday. I don't know what type of flow the 60 radiator is.
I got the alt wiring worked out without frying anything.
Still have to work out some clutch adjustment issues. Because of the driver side drop of the 57 chevy bell housing and the huge isuzu starter I had to make a Z shaped bracket and turn the slave cyl around 180 degrees. I can get enough movement to fully engage the clutch but I dont have a full 1/8" clearance at the throw out bearing when resting. Even though there is no pressure a few pressure plate fingers rub the bearing and spins it. I am using a return assist spring. The clutch pivot ball has some visual wear on it. I am thinking a new one might give me better travel
