The Big Drive!
Just came back from the first big drive. Did over 50 miles of freeway and surface streets and she's still running! No big issues at all...but a few small ones.
First the driving experience, Still its WOW! She really is different than than the 2f in so many ways. Completely different power band and shift points. When the turbo comes on, she just keeps pulling. Its weird to have power to pass and accelerate on the freeway, LOL!
With 3:70 gears and the H55 first gear is pretty short. It does not take much throttle to get underway, then it's time to shift. It seems best to drive the torque. Quick shifts in the low gears, then 3 is good for a wide range of speeds around town.
Until the turbo spools up, she's a little gutless. Like being lazy and leaving it 3rd gear after a slow turn up the freeway on ramp. A shift to 2nd, the turbo spools up and off we go. Literally! I have not had time to connect the tach or the turbo boost and pyro or gauges yet. So I driving a little blind, except I know my freeway speed rpm's. I've been driving by feel, and it's FUN!
She is not a silky smooth like the 2F. Let me restate that, she is smooth but a little rougher around the edges. More power and torque does that. It is not any louder than than 2F 90% of the time. At idle she may be just a touch louder, but when driving around town or the freeway the same or less. This engine is very quiet, and see no reason to make any sound proofing changes. Again, it's no louder than the 2F most of the time!
Vibration is minimal. Tiny bit of mirror movement at idle, and the center rear view flutters a little around 70 mph. That's it!
No drive line vibration issues, steers good, drives about the same as before. Brakes seem a little more powerful, I think due to the vac pump on the alt pulling more vacuum.
No smoke at all! Nothing on start-up or driving.
But all is not perfect in Toyuzu land. A few minor issues to deal with.
There is a little flat spot a low throttle/boost. Might be just how it is as the turbo kicks in. Just feels a little funny. I'm thinking maybe the the turbo boost compensator diaphragm is leaking? Ideas?
The belts are squealing when the turbo licks in. Their new, and probably just need adjusting.
I might need to see if there is any adjustment on the temp gauge in the dash. I wired the the 60 gauge to the Isuzu sender and the temp did not go over 1/4 at any time. But when the 2F was in, it only went a little higher. Maybe this normal?
The biggest issue is I have a rattle in the trans/bell housing area at idle with the clutch out and in neutral. Sounds like the clutch disc is loose. Engaging the trow out bearing does not eliminate the rattle, but push the pedal down does?Goes away when you push in the clutch pedal.
I need to adjust the clutch pedal free play a little, also the throw arm maybe a little loose. It did not make the sound before the long drive. Any ideas???? Everything is new, but it kind of sounds like a pilot bearing! It's new, and I hope not!!!!!!!!
I'll check it out tomorrow
Taking the rest of tonight of and having a cold Newcastle.
Doug
