Builds The Green Bastard (2 Viewers)
Keep those ujoints greased! The FSM yolk greasing guide is a bit vague and lots of folks have lots of warnings about Over greasing the told and damaging the transfer case, but you may have already seen those conversations.
Installed the VC120 today.
Greased 4 of the u joints, and 1 of the slip yokes in the drive line, the other slip yoke zirc was sheared off.
I love my vc120. Problem solved.
Got a partial draining of the cooling system in, put evaporust thermo cool back in, with around 2.5G of distilled water.
Found the radiator drain valve.
Used a concrete mixing tub as my catch basin (which it is also excellent for all types of fluid catching) and made very little mess on driveway.
Shipment of parts came in from BH3D and Solvefunction.
It’s a race! I just did my final cooling system flush, but anyone reading my thread knows my odds on winning are loooooooooog.
Nooooooo!
well, :poop:
1. Drained all of the thermocure. (Good) (Had to do this since the weather went from 70 today to just above freezing at night)
2. Successfully removed the block drain plug (Good)
3. While removing the block drain plug, and my 38" of extensions, I managed to mangle the threads on the plug, caused by the socket. (not so good, going to call around for 9643123814 tomorrow)
4. Went to look at the leaking coolant from behind the passenger tire discovered that the cabin heater under the rear seats has a rusted line. (not good)
5. Tried to remove the heatshield, and tried to remove the upstream O2 sensor (which just had a new fitting installed) only to discover that the senor would not lift off once the nuts were removed (called it here before I turned color in anger)
I think the plugs are available and can’t be expensive.
well, :poop:
You’re taking this in stride man. That sucks about the rusted line. Is it for rear heat or the front heat?
Good thinking stopping for the day. That’s the smart play. Lots of choices ahead and more opportunities to make the cruiser better.
my backup plan with the coolant plug is to try and clean the threads up with a file, since it is some british pipe thread
If the thread on the plug is tapered its probably ⅛ BSPT ( might be ¼BSPT) which is British Standard Pipe Tapered thread.
Typically used for water and propane gas. The tapered thread makes them self sealing (theoretically)
Oil fittings are more usually NPT - National Pipe Taper
They are similar, but not quite interchangeable.
rear heater line, one that snakes over by the exhaust.
Speaking of, going to see if anyone in town has 5/8 heater hose with a 90 degree bend molded in.
Goodbye rear heater
Goodbye rear heater
This is what you want, it eliminates a few more clamps and looks factory clean ;)
looks like that is OOS :(
I found a 90 degree bend at the local auto parts store, going to head that way in a bit, will just re-use the 180 degree fitting and send it :D
I have 1/2" gates green stripe if you need some. It's been hard to find locally for cheap.
