Pull that screw off at 6 o’clock and then beat on the drum all the way around it with a big hammer. It’ll come off eventually
Get a hold of @TRAIL TAILOR and see if he has repair pieces for that rear channel.
You can also get a couple screws and screw them in into them hole at the 11 o’clock and 4 o clock position and tighten them down one after the other and it should slowly pull out.
I know he has something there. Good quality stuff, it will fit.
Toyota has also come out with a new frame recall that involves coating the inside of the frame so I might look at doing that as well.
Can you point me to more info on this? Is it just for 62s? Sounds big.
