- Thread starter
- #201
I didn't mount the tire up, but it will be close. May need a bit more trimming, especially because I moved the axle forward.Is it safe to assume that your fender cuts will clear the tire at this articulation?
It looks like you tacked it to the knuckle??Had to cut and shorten the steering links because of the longer tie rod and y link adapter I used. Haven't finished the welding.
Ah. Right.No. Height of the air bumps is set by fully stuffing both sides. This height is different than when one side is stuffed and the other drooped because of how the axle pivots.
Oh I see the picture you're referring to. Those are the inserts Billy provides depending on what steering you're running; heims, 1 ton TREs or FJ80 TREsIt looks like you tacked it to the knuckle??
oh, Ok. I was wtfing for a moment but that makes sense.Oh I see the picture you're referring to. Those are the inserts Billy provides depending on what steering you're running; heims, 1 ton TREs or FJ80 TREs
Fixed.Keep it up mate so you can do mine next...
Haha if he wants to come to Aus on a 'Holiday' I can provide food and shelter in return for 3 linking.Fixed.
