- Thread starter
- #21
You mentioned wishing you had longer upper links, what kept you from pushing the axle back? Would also help with trimming the door area for clearance for 40's. I know the frame starts to dive back down, and you'd have to sort out coil bucket placement, but I don't think I've seen anyone really try to push the axle back at all to help with tire to door clearance and also end up with longer links and slightly better geometry.One thing I think would help tremendously is going to coil overs in the rear, mounted as far outboard as possible. Mostly to control off camber/body roll, and get the thing to feel a little more planted. I'm at the point I might do the rear before the front.
I also concur that these things have a ton of sheet metal to smash through. I do love being able to drive mine anywhere, wheel and return all self contained, my wife even love driving the thing distances. That is making removing the rear a little more difficult. Would be nice to drop the CG and get some clearance around trees in the roof line.
What is your approximate amount of lift? What coils are you running?
I really like how @Broski ran his rear anti-rock sway bar through the rear of the frame, would that help your situation with body roll? His truck appears wickedly stable off camber.....for an 80 series.
Appreciate the discussion from all.
