Techster’s 1973 FJ55 buildup...
Engine build pics.
The LS is a great motor. There's just no point in messing around with Chevy small blocks anymore unless you want period correct mods or something. The LS1 is going in the RX7 in the pics. Fits great and doubles the HP with minimal weight gain.
The aluminum heads didn't work out, but I had a set of very nice iron heads. They flow the same, just weigh 90# more. Got those all re-built. had to order new seals. The 99-00 seals are different from 01+. Had to order new bolts. Bolt kits come per side.
Got the motor completed, placed and bolted to the trans. The exhaust I had built didn't fit so it came apart and was re-done. Just about everything is wired. Just need to get rid of some extra circuits and re-wrap it all. It looks way worse than it is.
pic #1 fixing to drop with old exhaust. The right angle on the right side wouldnt clear the motor mount going in. I changed it to two 45s. It was easier to add the O2 bung then as well. The collector pinched between the frame and trans too. It will fit but needs to be rotated and maybe relocated a bit. Im going to have to put that in with the manifolds in place so no fun welding the joints.
Pic #2 - engine in place. Manifolds on and bolted up. 95% of the needed wiring hooked up
Man, im going to have fun trying to stuff a turbo in my engine bay!
Loving the progress picture!
Taurus fan. The aluminum block on top of the battery is my cooling hose bypass, high & low fan switch and coolant gauge manifold.
I'm running 98 corvette manifolds again. Take the right one and cut it right at the welded seam, rotate the curve 90 so it passes under the oil pan and weld it back on. You still have an O2 bung and it solves the transfer case issue.
What kind of impact?
Was way up straddling a pair of boulders. Started sliding down the backside and slid off too fast and sideways. Landed right on the rear transfer drain plug. The cruiser case held up, far as I can tell, but the twisting force broke the trans and 203 cases.
