Sunroof interior trim is broken and ratteling....Any good fixes? (5 Viewers)
KN4YJE LUGOFF, SC
I know this trim is NLA, I searched all over the place.
So I'm looking for good ideas on how to make it stop rattling.
I was tempeted to take it down and heat weld it back together from the back side, but it's brittle as candy and I'm afriad it will shatter into more pieces than can be reasonably reassembled.
Super glue? JB Weld? Take it out and make a wooden trim ring from....teak?
enox
Los Angeles, CA
Well. You may not like to hear this, but you asked for a solution...
Mine rattled and I also had a little water leak.
So when I did the bicycle tube sunroof seal fix, I bit the bullet and ordered new trim from the dealership.
Short from that would be remove the trim and try to put some felt tape where the corners meet each other. But you already know if you take it off it's gonna break.
No more rattle and no leak. This forum should be called ih8sunroofs.
mingles
GOLD Star
Titusville, New Jersey
Only the oak is NLA. I purchased the gray trim and painted it to match my oak interior. Works fine.
bonestock
Transportation Specialist
Lookout Mountain, GA
Subscribed. I actually replaced mine and it still rattles. It’s just the front pieces and, when pushed forward tightly, the sunroof cover helps keep the rattling to a minimum.
Socal
Can anyone post a photo of the black frame without the trim?
You can't tell, if you didn't know it had trim there. Wouldn't be surprised if poverty packs didn't have it.
It's nice to know the trim is still available if you're inclined.
Mine turned to pringles in the socal sun, rattled around, etc
It's not worth changing for me. Just one more thing in the way if I have to go at the sunroof to adjust again....
there are pics in this thread
KN4YJE LUGOFF, SC
So I thought I would try to oh so delicately attempt to get the broken pieces over my head out last night....
It exploded into half a dozen pieces. :mad:
So fuggit! All the trim comes out, in pieces if necessary. The only time I have the shade open is when I have the glass open, so the trim being gone isn't even noticed.
SmokingRocks
I bought a Cruiser to keep miles off my Cruiser
Colorado
All of these trim pieces in existence are as brittle as yours were, not only will they explode when you touch them but they explode into very very sharp fragments. What's unfortunate is to take the glass out to do the sunroof seal fix you need to remove the trim pieces to access the nuts. But like I said earlier, luckily the metal frame looks rather good exposed so it's not even something people notice. I'll try to get a photo tonight.
DFW
The section across the front on mine has turned to dust and fallen out, leaving the two sides to flap around and rattle. I was thinking of using some double sided tape to just hold it in place and stop the rattle. If the rest of it begins to crumble I'll just rip it all out and go naked.
Farmington NM
Mine is dry rotting from the NM sun and the front crumbled away. Taking them off as they chip and break and rattle. Stupid plastic.
So can we just break out that rectangular plastic ring around and below the sunroof glass? If I can remove it without dismantling or removing the glass or anything else, I'm in. Mine is broken in two places and looks janky as anything.
  • RDT
