The Mosley Radiator is worth its weight in gold. @cruisermatt actually saved my butt and sent me one he had on the shelf. I would run a Mechanical fan, skip over the electric... I did that. It's a waste of time. Heat soaked in the desert.
FYI the computer can fit above the glove box and below the dash.
and if for some reason you want to fiddle with the oil pressure fittings again. This one works for both
M16 x 1.5 PTFE Coated Steel Extension with 1/8 NPT Ports - Pegasus Auto Racing Supplies
Come check out our M16 x 1.5 PTFE Coated Steel Extension with 1/8 NPT Ports at Pegasus Auto Racing.www.pegasusautoracing.com
The guy is back making those speed sensor adapter things again or have you had that one?
About 6 years ago. He was taking over what his brother had started as he had passed away. I waited a long time but never got anything I came up with my own solution.He's still making them, bought it a few weeks ago, have you tried to order one recently?
Update
I bought one about a year ago and it came in like a week.About 6 years ago. He was taking over what his brother had started as he had passed away. I waited a long time but never got anything I came up with my own solution.
Looking great. Good call on the electrical - saved yourself 10-40 hours of work with that decision. Looking forward to watching this come together.Back in town and finally got a chance to get back on this thing last night. I'm going to be completely honest when I say that the spookiest part of this whole swap for me is the electrical aspect of it. I’ve done a decent bit of wiring over the years on some old hifi gear and installed stereos in every car I’ve owned but I’m a far cry from an electrical genius.
With that in mind my approach to the wiring on the swap is this – I’m going to keep the body harness and the engine harness as separated as possible. I do feel much more confident knowing that I have a great standalone engine harness from BP Automotive which also comes with fantastic instructions.
There are tons of things for the old 2F in the engine bay that I’m not going to use, but I decided against cutting off all the old plugs and dead-heading the wires. There were a couple wires that were pretty damaged that I did dead head, then I tidied everything up with some black electrical tape and hid everything through the fender.
I’ll be tackling the passenger side this weekend since I will be extending the Cruisertrash fusible link connection to the alternator along with the factory charge cable.
My initial plan was to install the ECU inside the truck so I started to remove my dash to give me better access. If anyone has got a half decent dash pad lying around that they don’t want an arm and a leg for let me know. Mine is completely toast and the defrosters crumbled in my hands as I removed the bolts holding them in.
The truck came with an awesome old Alpine shaft style stereo that worked pretty decently, but considering this is going to be my DD I’d like to have Bluetooth and a decent head unit. I didn’t want to cut the wires off of the old Alpine unit in case I decide to install it in something else down the road so I bought a universal stereo harness and spliced that in with the existing wiring.
I'm not going to keep the stock tach so I had bought a VDO with a 6k limit along with a mounting bracket from Trail Tailor. Got it installed in the cluster yesterday and looks really good.
With the dash pad off it's pretty clear that a Gen III LS ECU isn't going to fit under there, so I'm going to mount it in the engine bay like everyone told me to do and am going to keep working on it this weekend.
