- Joined
- Oct 22, 2013
- Threads
- 16
- Messages
- 258
- Thread starter
- #21
The strainer in the A440F doesn't need to get replaced, only removed and cleaned. It is a fine mesh stainless steel filter. There is a gasket for the strainer, but the transmission pan does not use a gasket. It uses the orange Toyota FIPG.
There are 2 magnets in the bottom of the pan that will collect metal debris.
BTW, did you make certain that your transfer case shifter is fully engaged in H? You might want to check that first.
Check, T-case fully engaged. I'd looked at that, but doubted just now and double-checked.
Yes, sure thing - clean-and-reinstall for the mesh filter. Good info on the FIPG for the tranny pan.
Orange 00295-01281 Local Dealership has this in stock.
Filter gasket, I think need a 35339-36010. Local dealership can have that for me by Monday.
I've had Vera for three years (unknown mechanical history other than red/healthy ATF came out when I did the drain/fill) and I've never dropped the trans pan. So, I'm thinking that should happen regardless.
Drain, Drop pan & filter, clean magnets and filter, put in new filter gasket and re-install filter, seal and re-install trans pan, refill with 4qts, run for a few seconds, fill rest of way.
Is re-drain & re-fill with filter cleaning the first step? Should I also try to adjust the kick-down cable at the same time, or first, or after? I'm trying to learn the right way to troubleshoot this, but with the filter gasket not due till Monday, I'm also wondering about steps I can still take over the weekend.
Also, question about over filling - I feel like that's a mistake I'd feel right away. Could that take some months to cause a problem? Also I wonder if I'm just a dunce at using an AT dipstick. I wiped it off and it seemed like it came out wet along the whole length - I just didn't know what to make of it. Seems a dumb thing to ask about, but oh well.
