- Joined
- Oct 22, 2013
- Threads
- 16
- Messages
- 258
I'm forcing myself to take deep breaths - keep the panic at bay that I've broken her real bad. Come what may, I'd really like not to have the expense of replacing or rebuilding the trans.
She's got about 230K+ miles, and I drained and filled the transmission fluid 3-5 months ago using generic Dexmerc, which claimed to be Dextron-III compatible. The old ATF that came out back then looked & smelled fine. Red, oily, nothing noteworthy.
Now to today...
Driving home from work today Vera's transmission went all wonky then stopped engaging. She's a 1991, so I think that means I've got an A440F transmission.
First I thought I smelled a hot oil smell, but it passed. I'm always paranoid at smells, and glance at the temp gauge, rear view mirror, and hood for signs of disaster (overheat, fluids in the road, smoke).
About 3/4 of a mile later, I was starting up a steep hill and felt like I had RPMs go way up to about the redline before it up-shifted. I made it up and over the hill, but smelled the burning smell again. Let off the gas and pretty much coasted down the other side of the hill in Drive, then drifted into a shopping center. It was slipping pretty bad and I limped it into a parking space.
I left it running and tried to check trans fluid, but it seemed to be reading really high on the stick.
I shut her down for a couple minutes, and then started and shifted into D. The trans engaged and I thought maybe I could limp the mile and a half home, but by the time I got 100yds to the parking lot entrance it was slipping 100% and I had to drift it back out of the traffic flow. Turned off for another 3 minutes or so, and tried fiddling with the CDL. Managed to limp into a parking space and then it was slipping seemingly 100% again with the CDL engaged. I couldn't get the CDL to turn off at that moment, I'm thinking she needs to be moving for it to disengage.
I can get her home. My folks are visiting and have AAA, but I'm about 51% sure that once it cools off I'll be able to drive home.
This just didn't fit the scenarios I've read so far. Most I read were partial slipping, slipping in certain gears, or stripped drive flange (which I think engaging the CDL would have tested). The one that scared me was the one that went with a bang. Anyway, I'm hoping it's something I can fix at home - I've rebuilt the birfs, replaced the water pump, replaced springs and shocks, and rebuilt front & rear brakes for whatever that tells you about my mechanical abilities. That said, I struggle to troubleshoot without help from MUD, and this is my DD, so any troubleshooting tips would be urgently appreciated!
Now to today...
