- Thread starter
- #21
Tried these numbers on Toyotapartsdeal.com and nothing popped up. NAPA has pigtail knock & starter connectors so it's all good.you can buy the knock sensor connectors from Toyota. I replaced both of mine and the starter plastic connector when I did my starter . here are the part numbers
starter contact plug 90980-11400, also 90980-09585
knock sensor plug 1 90980-11166
knock sensor plug 2 90980-11166
The only times I've seen knock sensor codes, is rodent damaging wire.
Number one procedure before removing anything, expect engine cover. Clean top of engine. Paying special attention to both sides where intake manifold meets the heads. You do not want even one dust practical dropping into intake ports of heads. Also, before installing intake manifold. Get on top of engine with flashlight and vacuum out any dust/sand from each intake port. These two step alone, add 1 to 2 hours to the job. Shop's are trying to beat the clock, so they don't do this. But pros, at least blow off with shop air.
Procedure for replacing 100 series(98 and up) starter contacts
forum.ih8mud.com
Knock sensor wire cut, what do I do HELP
Mickey & Minnie nesting in the engine valley, snacked on the wire(s). With a P0325 (knock sensor #1 bank #1) and a visual inspection. I was able to confirm at least one wire is cut. I was thinking I'd just splice the wire, possible adding a small section if need be. The I realized this is a...forum.ih8mud.com
These butt solider splicers are the way to go, a one and done.![]()
They are just different sizes, not sure if your sizes are correct as we have the metric system in the uk so AWG is alien to myself.forum.ih8mud.com
Denso starter is fine, but Toyota Denso is remanufactured to higher standard with specific list of parts. In either, I reset contacts.
I always have the starter single wire housing block (OEM) on hand. The lock almost always breaks. All wire house blocks have a number on them, which is last 5 of P/N. To date, every engine wire block housing I've needed. Toyota has had available, most in stock locally. Once I needed 7 for a signal starter job, all were in stock.
I was thinking they made these knock sensor wire & connector kits because Mickey & Minnie's favorite home. But now I see it must be because these often get brittle and break when replacing sensor.forum.ih8mud.com
The water cross-over pipe, can be left in place. But if removed, replace the small O-ring. I use Dove dish soapy water, to lube O-ring for install.
If working on a VVT engine. This is the time to mod the S.A.I. filter.
Head cover gaskets, I've re-torqued the cover bolts to 53IN-lbf on over 100 4.7L engines. Stopping leaks/weeps 100% of the time. The only head cover or spark plug tube seals I've replaced. Is where I came in behind one's replaced by someone else. Eventually, they'll need replacing I suppose, but I've yet to see it!
Nice time to replace fuel inject seal, is while intake manifold off. No real need to split intake manifold on the 98-05, its gaskets is fine if undisturbed. If you've the time, sending out fuel inject to be cleaned, rebuilt and tested, is a nice touch.
Look for any sign of seepage at front and rear water bypass joints. Any sign, replace the gasket. I've found those gasket in great condition, if no sign of coolant seepage. So I only replace (both banks) I do see signs of seepage.
VVT
Replace any and all seals disturbed.
Use a torque wrench!
Thanks for sharing this book of wealth.
Why do you advise not replacing the knock sensor if it's just a wire issue?If wire or wire housing block cut/bad, I'd not replace the sensor. I do have two used in stock, if you feel the need to replace.. PM/DM me.
