Shackles and Steering Angles
Discussion in '40- & 55-Series Tech' started by mutt, Feb 23, 2007.
  1. mutt
    mutt
    44
    Feb 12, 2007
    Tallahassee, FL
    I want to get some thoughts on the steering set-up my 40 came with. I've downsized to some 32's in an effort for less "squirrly steer", and want to possibly drop down the height a bit with some shorter shackles before getting an alignment. Any thoughts on the steering set-up and angles, and what shackles to go with? I'm not sure how much over stock I'm truly at now. It's supposed to be a 4 inch Skyjacker lift. Also what kind of stabilizer can I run with the conversion? There's nothing in place now. Is that one of my major problems?
    Steering taken from close to level with axle.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Rear Shackle
    [​IMG]
    Front Shackle
    [​IMG]
    Also is the spring pack missing a leaf of does this look correct
    [​IMG]
  2. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    stabilizer is a band aid.
    i do not run one with my sag steering, when were your knuckels last rebuilt (bearings etc,)
  3. mutt
    mutt
    44
    Feb 12, 2007
    Tallahassee, FL
    No idea. I've only had the rig a couple weeks and I'm just trying to figure out my next step and what all's been done to date. Any thoughts?
  4. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    pita but i would rebuild the front end. maybe go back o stock length shackles as well
  5. mutt
    mutt
    44
    Feb 12, 2007
    Tallahassee, FL
    Could I go stock height with 32's or can you tell with the springs not being stock?
  6. John Smith
    John Smith In the garage
    4,187
    Media:
    6
    Albums:
    2
    233
    Jun 7, 2004
    Maryland
    Your "squirrly steer" is due to the extended shackles with the skyjacker 4" lift and no caster shims. You suffer from a lack of caster. Install a 4 degree shim in the front and you will wonder how you ever drove the truck in the current state. I used to run the *exact* shackles and lift you are running and thought I was going to die until I got some 4 deg shims for the front. Install with the fat part towards the front of the truck to tilt your axle back. Because of your draglink angle you will probably still have some bumpsteer but you will notice a huge difference once you have caster.
    And you are not missing a leaf spring, that is how they come.
  7. Pin_Head
    Pin_Head
    14,459
    2,033
    Feb 6, 2002
    OC, CA
    X2
    negative caster and bump steer would be a pretty "squirrly" ride.
  8. randle
    randle
    132
    Jul 26, 2006
    on the north side of town
    i could be wrong, but maybe a drop pitman arm would also help the bump steer.
  9. Tankota
    Tankota
    388
    May 4, 2006
    Olympia, Washington
    That box is a few inches further forward than most I have seen. This results in a bit of a double direction thing...your lift took your drag link and tie rod out of alignment and the far forward box mount took the alignment even further away.
    You could move teh box back a bit. Move the front end forward (you can get 1" by redrilling the spring perch pin holes).
    Or you can get a longer drop pitman arm. This one kicks but...
    Grand waggie... You could also try a scout 2 pitman arm. I had one for a while but it was longer than I needed.
  10. Mark W
    Mark W
    6,182
    90
    Jan 7, 2005
    The Greatland
    Putting a longer pitman arm on in an attempt to change the alignment of the draglink is not the way to go. Longer pitman arm produces quicker steering (fewer turns of the steering wheel for the same amount of turn of the wheels/tires). Usually not a good idea. Especially with steering that is already squirrelly.
    Mark...
  11. Hugh Heifer
    Hugh Heifer In Tenneginia!
    6,252
    Media:
    26
    Albums:
    3
    739
    May 10, 2006
    Bristol, VA
    I thought that realigning the draglink (At least out of that major angle) with a drop pitman would provide smoother action and less wear to the draglink ends. The angle of the drag link in the first pics looks way wacky to me.
    Mark - do you think that angle is ok? (I ask as I have a similar set up on my '71.)
  12. mutt
    mutt
    44
    Feb 12, 2007
    Tallahassee, FL
    Would a drop arm of the same length be the best of both worlds?
    If I wanted to drop things another inch with some shorter shackles, what would that be over stock? It seems most are labeled that way rather than by their length.
    Thanks for all the help
  13. gladly
    gladly User title
    1,019
    32
    Apr 16, 2005
    I think that one of the reasons that folks generally run longer shackles with lift springs is that since the spring is more curved, it will be longer as it compresses and flattens.
  14. Mark W
    Mark W
    6,182
    90
    Jan 7, 2005
    The Greatland
    A dropped arm would help. You want your drag link to be as close to horizontal as possible to reduce bumpsteer. Won't really affect the "smoothness" of the steering though.
    With a steep angle of the draglink when the rig is sitting static, you may actually find that under high flex, the tierod end runs out of movement range. But an SUA rig with lift sorings usually won't flex enough to run into this problem.
    The forward location of the box and the angle that results is pretty common with this type of Saginaw conversion. Usually results in some degree of misaligned steering. That is, you have fewer turns of the steering wheel in one direction from center than the other.
    Mark...
  15. MDH33
    MDH33
    1,211
    45
    Jul 5, 2005
    Ames, IA
    I agree, I thought it was necessary to run the longer shackles with lift springs to allow the springs to fully flex and flatten.
  16. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    19
    Jan 22, 2003
    Kansastitty
    A shackle that lifts your truck 1" will be 2" longer than a stock shackle. I got my steel weld-on shims from Roger Brown at 4crawler.com. Try here for a bunch of good info and ordering instructions...
    http://www.4crawler.com/4x4/ForSale/Shims.shtml#Questions
    Ed
  17. peesalot
    peesalot
    2,334
    64
    Sep 20, 2004
    in a house
    move the steering box back 3" and get the shimms. it sucks that some cob put the box so far forward. Another solution is to flip the front springs, that would slove the misalignment and bring your caster back a little so 2* shims would work or maybe no shims.
  18. Tankota
    Tankota
    388
    May 4, 2006
    Olympia, Washington
    Spring flip! Good idea. Forgot about that one.
  19. Brian Noon
    Brian Noon
    1
    Sep 29, 2006
    Brian Noon
    Hi i am new here. i own a 67fj and love it i am restoring bit by bit. My baby has a Chevy 283 w/3sp on the floor 12.000 pto winch:)
