The other thing that must be taken into consideration if you choose to pack your wheel bearings with grease: The wheel bearing grease MUST be compatible with the gear oil used.
There are certain types of greases and oils that are NOT compatible with each other. They will turn to cottage cheese and clump up and not lubricate anything because they don;t like each other. In the case of the rear wheel bearings, it is not a case of "if" it is a case of "when" they will mix.
