Couple of things after just completing a 1300 mile road trip in 90+ degree heat. Loaded, auto climate control temp set to 75, highway temps steady at 194-198 at 65-70 mph for hours on end.
Denso is NOT the OEM for Toyota radiators. TRAD is the OEM.
Your local Toyota parts department will show 16400-66081 for the 1996 radiator, however 16400-66040 for the OBD1 FZJ80 fits as well and has better cooling capacity. That's what's in my 97 LX450 right now.
The OEM radiator cap (16401-54750 that comes with a new OEM radiator) is critical for proper cooling.
The OEM thermostat (90916-03117) starts to open at 180F (82C) and is fully open at 203F (95C). If your temps remain within this window, then the cooling system is operating properly.
The statements regarding the blue hub fan clutch modifications are also critical and can't be overlooked. Out of the box, a new blue hub is fairly weak and this has been documented multiple times. Both the amount of supplied fluid and port opening temps vary widely.
Several years ago I modded my blue hub according to my typical driving conditions here in the northeast. I would strongly suggest you do the same. Normal driving without AC on she sits at 186 all day. Winter cold/summer heat makes no difference.
I added thin self adhesive closed cell foam to the front side of the fan shroud to get a tighter seal on the radiator.
As previously stated, the upper and lower foam that is supplied with the new radiators is also important to keep air flowing through the radiator as opposed to around it.
Another thing that shouldn't be overlooked is the thin metal pan that sits under the very front of the chassis (51441-60200) and has a cut out for the steering damper mount. This also helps to direct airflow at speed.
NOTE: Some will say (mostly Facebook knuckleheads) that the engine fan does nothing at highway speeds. This is 100% incorrect. These engines cannot stay cool without a properly operating fan clutch at any speed.
