rear body mounts
Question on your a/c vents.... Are you using two outlets for the side defrost vents? If so, that would leave only two more vents for the front dash, not four, right? Restomod has four outlets in the front and four in the back, I believe.
Is there a rule that AC buttons need to be in a straight line?
Think my boy Nookshneer has found me the radio.
I Removed the stress of this dash layout by realizing that I can always cut a new dash later if I don’t like this one!
Your 🐷 no rules! Do whats comfy! Grab a milk crate and a 🍺 and pretend your driving the 🐖 all around, where do you want your controls 😉? Just dont fiberglass your dash 😂🤣😅🤪
I am using the four cab facing outlets for the dash, and will be splitting the four firewall facing outlets between the floor, side vents, and front window. Talked w Tcarrier and he used only one for the floor and the remaining 3 for the defrost (side vents and window). Suggestion was to use one for the main driver Defrost and split the remaining two on the side and window defrost.
Does that make sense?
How has your experience been?
I used both yours and Tcarrier’s as my guide. As I said I got a little more in-depth counsel from Tcarrier because he said he had great results.
@xtiaan2000 Yo! Figured out the best vent position location. I forgot to ask my boy in Ali out in Ahwar, Yemen.
He said that if you want the deluxe version with Dual Climate control that’s another 12,514 Rial.
Wise decision! I'm not totally happy yet. Due to my vent placement and/or power of the fan, I don't feel the cool air blowing in my hair. :) This will be fixed some how, either a booster fan or also a second unit behind the seats blowing back at me. I had a lot of trouble with enough room for all the vent tubing and keeping it out of the wiper system's way. I made it worse by recessing the middle part of my dash. :doh:
