Builds Project Lockjaw-1973 Fj40 on Tons (3 Viewers)
Trying to find information, and I've tried searching.....someone did a build where they ran headers out over the frame and the exhaust thru the front body/running board mount. Does anyone know who this might have been?
My junk is like this, old Downey conversion headers on a SBC. What exactly do you want pics of, I’ll take some more tonite.
Maybe some pictures of your headers and routing of exhaust. There was someone else also on a current build that ran some Sanderson type headers. They notched out the running board mount with a 3" hole saw.. Then the muffler in behind the rock slider mounts.
That’s what mine look like too. I’ll snap pics in a bit after kids on bed
This?
With the Dana 60 packaging is tight. I've got the lower link and upper link on the passenger side. Then there is the lower link and drive shaft on the drivers side. All are fighting for room
Got a little work done on Lockjaw today. Got the 4x4Labs brackets tacked on and the Redhead Gear Box mocked up. Cut out a 3/16 piece to fill a hole on the crossmember.
Hey Guys, Not looking hijack this thread but I need some support.
Just completed my 2006 5.3 vortec/NV4500/Orion swap.
I need a fuel delivery system and looking for recommendations and advice.
This is my first Rodeo, hence support needed. I done my homework and search Mud and Pirate without great data.
Any support would be greatly appreciated.
I would like to run a fuel cell as well.
Thanks,
Thanks,
Rutters Rod Shop this is the #SKU: PA-2 for pump and pick up I used on my 6.0 swap.
Thanks,
Here is another option:
Post in thread 'Thomas FJ48 Build'
Thomas FJ48 Build - https://forum.ih8mud.com/threads/thomas-fj48-build.1270695/post-14195667
Thanks,
@cruisermatt
Thanks,
If you want an off the shelf option : 2004 Tahoe in-tank pump works well for me in a stick tank. Only time I hear it is just before start up. Theoretically, an in tank pump willl last longer due to the fluid around it cooling it. I found an inner mounting ring at Tank, Inc and fabbed the outer one. Details are in my build.
  • klip
