Pretty quiet in here... what are you working on? (15 Viewers)
I had a feeling if someone planted the idea in your head you would research and come up with a good one:)
Adding to wish list now...
I wonder if it will help with removing frame rivets??
I would say a grinder and a air chisel would take care of those.
Another alternative, build your own induction heater.
@iptman Sorry, I don't have it anymore. It went to a new home a long time ago.
We went to the beach three weeks ago and, 15 minutes before our departure, the driver's window on the 62 wouldn't go up. Doh! I taped a plastic bag over it while the family waited patiently in the 100 and I left it to its fate for 8 days. It held with some help from the neighbors.
I finally got around to getting into it. @emorth had helped me to replace the relays in the door four years ago, and when I say help, I mean Ed replaced the relays. I assumed that was the problem as that is a common gremlin in a 62.
I pulled everything apart. The switch, the relay, and the motor all seemed to test fine so I plugged it back together and it worked. Hmm. I'm assuming there was a cruddy connector that got cleaned in the process. There was no ground in the door to clean.
A whole lot of work in 100+ heat index for a whole lot of nothing, though I suppose that is better than finding a whole lot of something.
You can replace the relays on the factory board. Check this thread FJ62 Drivers Power Window (AutoDown) Relay Fix
Niiice, I hadn’t seen that thread before. Good to know.
I was thinking of this one which outlines adding relays to the passenger and rear doors to fix the slow windows and locks. It’s on my to-do list. Also going to add sound deadening while the panels are off.
7-pin mod, shoulda done it a long time ago!
Bending 1/4 inch 304 stainless tubing to replace the fuel related lines:
paper trace of the bends in the x and y plane:
zip ties to help with the compound bends:
Ran out of shade... :confused:
sliders and a bumper too... nice
quarantine has been good to her...all that bar and restaurant money I haven't been spending has gone to land cruiser parts...
