I have a 96 fzj and im about to go on a trip. Front driveshaft has bad u joints. Is it ok to drive without it? Thanks
How do i lock the center diff? Dumb question but I don't know the procedure.
what fuse is it called? i appreciate all of the information.
If you don't have a center locker button installed, you can put it in Low Range, then pull the fuse before putting it in High Range again to keep it locked
If you don't lock it, you will smoke your coupler in no time![]()
Will it reset if the car is shut off?
Geof
I believe my VC is seized, but I am having a hard time wrapping my head around the above statement (I am not attacking you) It seems to me, if the front driveshaft is removed then the front and rear output flanges of the transfer case are moving at the same rate all the time, and not different rates, which is the cause of a seized VC...
can someone enlighten me?
