Hey folks I am thrilled to be included in this group as a 1st time ever LC owner, a 200 purchased from a family member. I'll be the 2nd owner from new. I am putting together a baselining guide for myself and had some blanks to fill, and thought it might be useful for others.
Pics to follow and when the time comes will do a build thread, because, duh, you have to build these, right?
Details: 2008, Super White over tan, some dings and scratches, 2 fender bender repairs over the years. no pressure to keep it perfect.
Mileage: 159,298
This was my Aunt's road warrior - might have gone off road onto gravel or dirt a few times, toughest outings hauling dogs and tailgating football. But otherwise commuter all over the SouthEast.
Now, to the baselining list. I've been all over these boards extensively, but forgive me if I missed something - there is a LOT of info here.
Main FAQ thread:
And the Common Failures & Repairs FAQ:
Fluids:
Brake bleeding:
Need to check fluid, several brake jobs over the years, unclear if ever fully bled
Transmission:
Is this required? Not listed in factory maintenance schedule through 120k when it stops, unless off-road/towing. Feels like a yes. Never been done AFAIK.
Diffs/Transfer Case:
Youtube guide: My Videos: Changing the oil in the front/rear diffs and transfer case
Never been done, do it?
Oil changes are up to date but will continue the 5k interval.
Power Steering:
Flush fluid? Is there a filter with the pump?
Coolant:
Done recently due to water pump, thermostat, belts and Radiator, but feels like a check for Toyo red (or whatever is correct for 2008?)
Lube:
Propeller Shaft
Drive Shaft bushings: SQOD Squad - Stupid Question Of the Day
KDDS:
Inspect and lube if needed, mitigate any rust
other? what else takes lube down there? wait - don't answer that one.
Re-torque:
Prop shaft bolt?
All the suspension-y things
All the chassis things
Where to find all torque specs?
Other:
Hoses:
Inspect
Proactive Maintenance:
Starter
Initial Improvements:
Lighting:
LED bulbs? or high from 2011 up? SQOD Squad - Stupid Question Of the Day
Storage box: Amazon product ASIN B01KCP5VK6
Wheels & Tires! Stat!
Bluetoofs
Saw somewhere I can't find now a really good "cheap" dongle to add BT Audio
Longer Term: The Build:
Nav Delete? Need to relo that thread too.
the very long tail and deep rabbit hole of overlanding/offroading mods. Not yet . . .
thanks for the input y'all, stoked. I'm coming off leased Mercedes GLS - latest a 550 - they are fantastic and quite capable but not long term relationship worthy, IMO. Need something sensible
Mileage: 159,298
- Maintenance (all records available)
- Routine oil changes every 5,000 miles (synthetic)
- Routine oil filters, air filters, coolant, rotate tires, etc
- Brake pads, battery replacement (once or twice)
- New thermostat and water pump @ 140,710 miles
- New radiator @ 146,469 miles
- New Michelin tires @ 156,620 miles
Main FAQ thread:
200-series FAQ for Modifications, Repairs and Build Threads. Great place for new users to start
The Frequently Asked Questions (FAQ) for the 200/LX570 series tech section continues to be a work in progress. The goal is to have links in the below to other threads and tech articles. By having these linked, instead of pasting the text, the threads will remain live. The live threads can...
forum.ih8mud.com
Common Failures and Repairs - FAQ
This is an FAQ thread. That means no chat or discussing the items posted here. You can go into one of the threads linked based on topics for questions The reason is to help the reader sift through data rather than chat to help solve their issue. Each post is a single topic with Links to...
forum.ih8mud.com
Fluids:
Brake bleeding:
What is the brake bleed sequence for 200?
Just picked up a 2010 LC and baselining my fluids. Can someone tell me the brake bleed sequence for a 200 series? I am assuming PS Rear, DS Rear, PS Front, DS Front. Thanks!
forum.ih8mud.com
Transmission:
Power Steering:
Coolant:
Lube:
Propeller Shaft
KDDS:
KDSS valve rust- WARNING
Guys please take a look at your KDSS valve and give it a coating of grease. I had mine replaced under warranty because it was frozen and the replacement looks like this at 12 months old. I took the wire brush to it and gave it a good coating of Yamaha marine grease. Applied grease with the...
forum.ih8mud.com
KDSS - UNfrozen! :) How I did it...
As several folks here have discovered, the KDSS cast housings are prone to rust (this is possibly the understatement of the year). The valves - which need to be opened in order to level a vehicle while installing a suspension upgrade - are conveniently located in the place most vulnerable to...
forum.ih8mud.com
Re-torque:
Prop shaft bolt?
Other:
Hoses:
Inspect
Starter
Lighting:
200 Series Tire and Wheel Size Database
I want to give a shout-out to @DirtNap. He has updated my database and made it more user friedly. UPDATE #1: A disgruntled member keeps deleting portions of the database, so I had to remove the editing abilities for everyone. :meh: For now, just submit your info via a reply to this thread...
forum.ih8mud.com
Bluetoofs
Connecting A New Phone to Your 200 Series
If your truck is used or you just got a new phone (like a 6s) here are the direction for connecting the phone and it's Bluetooth audio: Go to setting-phone-manage phone-options-select all-delete Go to -settings-audio-Bluetooth Audio settings-remove-and remove all devices Turn off car and...
forum.ih8mud.com
