Builds My 1978 Nut and Bolt Frame Off Restoration (2 Viewers)
Tire carrier is located and mounted.
image-jpeg.1280688
image-jpeg.1280690
Moment of truth: Checking to see is the top still fits, and the body hasn't warped when welding.
Success!!
image-jpeg.1280691
image-jpeg.1280692
Fitting the ambi doors
image-jpeg.1280768
This is the best I can do as far as fitment. Should be a little more adjustment to do during final assembly.
image-jpeg.1281103
Stripping it back down
image-jpeg.1282546
Body is off!!!
image-jpeg.1282862
image-jpeg.1282865
image-jpeg.1282870
Got a TON done this morning.
Removed skid plate, bump stops, battery tray, heat shields, distributor, driveshafts, steering box, rear struts, all remaining wiring harnesses, all remaining brake lines and associated brackets, exhaust, engine mount bolts, and most of the remaining soft and hard fuel lines.
Also gave it a good pressure washing.
The engine is floating on the frame and is ready to be pulled.
image-jpeg.1283407
image-jpeg.1283408
image-jpeg.1283409
image-jpeg.1283410
image-jpeg.1283411
Pittman arm removal was a major PITA!
image-jpeg.1283889
Done:
image-jpeg.1283890
Axles and steering linkages disconnected
image-jpeg.1283893
Axles and leafs are out. All that's left to do now is pull drivetrain; hopefully in the next few days.
image-jpeg.1284283
Engine is out!
image-jpeg.1284967
Steering pedestal removed
image-jpeg.1285458
32 lbs ready for cadmium plating
image-jpeg.1286848
Fuel pump and power steering parts ready for plating
image-jpeg.1287526
I blasted and degreased my e-brake drum and gave it a coat of black and then clear coat. This'll be what the engine would look like it I went forward with it:
image-jpeg.1287541
Removed tranny and transfer case. Drained oil from both, and filled them with a mixture of diesel fuel and ATF to clean out any deposits.
image-jpeg.1288241
image-jpeg.1288243
Got the bell housing, flywheel, clutch removed. Sure enough, the rear main looks like it has a small leak. Good thing I've got a new one in order.
My throw out bearing was partially seized; got a new one of them too. Also ordered the spring clips that hold the clutch fork to the throw out bearing, inspection covers and boots for the bell housing, new gaskets for thermostat housing, water pump, timing cover, fuel pump, and oil filter housing.
I've found a number of after market bolts; it obvious this truck has had clutch job sometime in the past. Those will be replaced with cadmium JIS harware. I also noticed a lot of missing bolts; those will also be replaced with CAD JIS hardware.
The flywheel looks nice. I'll just clean it up well, and give the outside a fresh coat of paint (not the mating surface obviously).
Oh and good news; my pot blaster comes in today. I'll be going to Tractor Supply to pick up about 400lbs of blasting media later this morning.
image-jpeg.1288590
Got an engine stand
image-jpeg.1288700
