This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
obsessive-compulsive oppositional-defiant wise-ass
Slowly getting things off!
(That's what she said)
Andrew - Purveyor of Homebrewed Beer, Class III Weapons, Lawnmowers , & LandCruisers
T LCA # 23407
1997 FZJ80 Collector's Edition Currently restoring back to its former glory.
1978 FJ40 Currently under a full nut and bolt frame off restoration
2003 UZJ100 Wife's Rig
I sell 80 Series Steering Wheel Leather Kits. IM me for details.
T LCA # 23407
T LCA # 23407
Started pulling things out of the engine bay
T LCA # 23407
As I said earlier in the thread, the hood has a lot of damage. There was a massive crease on the passengers side; so much, that the bib over hung the hood by about 1.5". I tried banging out the crease but it was too far gone. I then cut the crease out with an angle grinder and cut a patch of 16ga steel for the hole.
Lines up much better now!!
T LCA # 23407
Did more work in the engine bay. Pulled all the brake and clutch lines, reservoirs, fans, master cylinders, booster, and brackets. I also removed the pedals, brackets, hardware, and cables.
Now that the hood lines up well, I can start pulling fenders, bib, aprons, etc.
T LCA # 23407
T LCA # 23407
T LCA # 23407
T LCA # 23407
Got a huge score today from another member.
24 lbs of freshly cadmium plated metric JIS hardware from a previous FJ40 project that never came to fruition. Probably close to 2000 nuts, bolts, screws, studs, and various other pieces.
T LCA # 23407
T LCA # 23407
T LCA # 23407
Blasted and painted valve cover
T LCA # 23407
Lots of parts have been blasted and are ready for Cadmium plating (decided to go with CAD instead of zinc).
T LCA # 23407
Bought a vibratory tumbler from Harbor Freight, and have been tumbling all of the hardware I remove.
T LCA # 23407
First lot of hardware after about 8 hours in the tumbler. Wow, they came out spotless.
T LCA # 23407
New 16 CFM Quincy air compressor.
Overkill, but I'll never have to buy an air compressor again.
T LCA # 23407
Old rear sill is out; it was rotten. New sill is currently being fitted.
T LCA # 23407
T LCA # 23407
T LCA # 23407
