This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
obsessive-compulsive oppositional-defiant wise-ass
So I'm kinda obsessed with my new blaster.
Andrew - Purveyor of Homebrewed Beer, Class III Weapons, Lawnmowers , & LandCruisers
T LCA # 23407
1997 FZJ80 Collector's Edition Currently restoring back to its former glory.
1978 FJ40 Currently under a full nut and bolt frame off restoration
2003 UZJ100 Wife's Rig
I sell 80 Series Steering Wheel Leather Kits. IM me for details.
Back side of flywheel (and no, of course I did not blast the pressure plate surface)
T LCA # 23407
Bellhousing was blasted, cleaned with denatured alcohol, 3 coats of semi gloss black VHT paint, and filled up with 3 coats of VHT clear coat.
T LCA # 23407
Driveshafts are finished, after getting the same treatment as the bellhousing.
New zerk fittings and Royal Purple Grease too.
T LCA # 23407
Got bored. Painted the flywheel alignment/inspection indicators.
T LCA # 23407
Needed a solution for holding bolts upright to blast the heads that didn't come out of the tumbler clean.
Used an old grill sauté pan. Worked perfectly.
Man, I've spent a ton of time getting these things perfectly clean. I can't wait to see what they look like when they come back from plating.
T LCA # 23407
Special delivery from
@beno
T LCA # 23407
Thermostat housing has been blasted, degreased, painted with high temp silver, and a high temp clear coat. New thermostat and all new gaskets (from
@beno of course).
T LCA # 23407
New water pump and gaskets, blasted and painted fan clutch, and zinc chromate plated fan pulley (courtesy of
@wngrog )
T LCA # 23407
Intake manifold has been blasted, degreased, and painted.
T LCA # 23407
Finally got all my hardware prepped for cadmium plating. Woohoo. I would say I've got at least 50 hours in those alone.
Box came in at just under 48 lbs. Wow!
T LCA # 23407
Oil filter pedistal, and sending unit are done. New and discontinued Toyota oil filter, along with all necessary gaskets courtesy of
@beno
T LCA # 23407
T LCA # 23407
Spent the morning blasting the block. 150lbs of blasting media. Coated with high temp semi gloss black and high temp clear coat.
(If you are reading this now, the engine was eventually completely stripped down, disassembled, machined, and rebuilt by a professional shop a year or so after this post was originally made)
T LCA # 23407
Blasted and painted the inspection cover. I just happened to have the right cadmium bolts in my shop to install it. Also had a few for the timing cover. I ordered a new timing cover gasket from
@beno .
T LCA # 23407
Decided I'd just get the inspection cover PC'd instead.
First batch of parts dropped off at the powdercoater.
T LCA # 23407
I've been blasting the frame. About 2/3 of the way done. Booya.
T LCA # 23407
Looking good! What size compressor are you driving the blaster with? It looks like it is doing a great job. When I considered getting a sandblaster, it seemed like I was going to need a pretty big compressor, so I had a guy come to my house and take care of it. Your rig looks like it was in pretty decent shape to start with.
Who is doing your plating?
Looks good! How long have you been working on things?
Dropped the frame off at the powdercoater this afternoon.
@wngrog let me borrow his trailer. Thanks dude!
T LCA # 23407
