Builds Moonshine - A Build Thread (6 Viewers)
Which are your highway rpm at the moment .. ?
~70mph @ 1850rpm. Based on my math, that will go down to ~65mph @ 1850rpm with 35s, which should still be good.
why not 37" all-terrain or street tires?
Go ahead and find some for a 17" rim. I can't.
Besides, I wouldn't mind my EGTs being lower.
~70mph @ 1800rpm. Based on my math, that will go down to ~65mph @ 1800rpm with 35s, which should still be good.
that's pretty low .. I'm way over that .! damn .. those Toyota manual trannys sucks !
I double-checked yesterday and it's actually ~1850rpm at 70mph. In any case, I think I'll be good. :grinpimp:
I'm at about 2,100ish at 70. I still need to adjust mine correctly. All the calculators say I should be around 1,900.
My speed is measured via GPS with the APRS unit in my 2M radio. The factory speedometer is just decoration now :lol:
Is there a cable speedometer provision on the Dana 300? I wonder if you could make a custom cable and plastic gear for it to be accurate.
Yes, there is (and it's hooked up). The speedo reads maybe 7% faster than GPS speed. I could make it accurate, but that project hasn't made it far enough up the list of needs.
If you go with an electric aftermarket you can program it to a GPS unit if you choose. Good item if you switch back and forth on tire sizes
Hey Johnny loving the wheels! ;) I had to re center my H2 wheels since I am running the ford axles
Miss seeing you at CMCC 15. Oh well maybe next year.
Moonshine got some "new" wheels and tires this weekend:
Ohh, Desert Grapplers! I bet they feel smoooth
Nice wide stance. Time to take that to Moab!
