Builds Moonshine - A Build Thread (8 Viewers)
That's a lot more compact than the ANL fuses. I might go that route.
let me know how it ends .. I do have my batts on Tencha on parallel no fuse but my cables were behind my rad over my electric fan setup, covered and zip tied ..
Where do you have a 3/8 stud?
The military terminals? These little fuses can be mounted on its side no problem :D
Will do! I am picking up loom tomorrow, but from the sounds of it, even if I moved the cables to the fan shroud I would still be dangerous.
From ONSC's annual Christmas Party this past weekend. Credit to videographer @jamesurq. First attempt is in 3rd gear, then you can see me ask @jfz80 if I should try fourth, which I then did :lol: As a reference, I had her up around 3500rpm for this climb while in low range and 4th gear:
Mark, all you have to do is "loan" me $3k and I'll have ARBs installed before Christmas :p
Hell yeah ! this it's the kind action we ( I .? ) wanna see !
your D300 it's 4:1 ..?
I'll never be able to do that in Tencha .. ( like 3rd but never 4th gear .. )
Looks like fun. Love the cloud of black smoke 1/2 way up.
Not sure the lockers would have helped much with traction equally bad on all 4 wheels! Kind of like sand, only harder to clean!
So in that picture I've got my new ATs on. Finally got them installed after correcting my alignment.
When you going to get some protection on that beast? Sliders, corner protection?
At some point in the future :D Busy working on other people's trucks for the past year and a half!!
No, he has the LowMax kit. Factory D300 low range is 2.72:1. Still a slight drop from the splitcase's 2.27:1.
What Matt said. The Low-Max gears are awesome!
The only reason I didn't jump to the 4:1 on the split case it's I found myself shifting to Hi gear several times in the trail ( when gotta move faster ) and I don't like it .. guess you need to do it often ..
A sweet setup would be an H55f/Blackbox/D300
Yeah I mean you're set there, it's a great case if you want center rear output but it's not necessarily worth ditching the split-case for.
I was going to put an NV4500 and Dana 300 behind my 3fe to the 80 rear until I got such a good deal on a 203/splitcase adapter from John S.
