Build Moonshine - A Build Thread
That's a lot more compact than the ANL fuses. I might go that route.
let me know how it ends .. I do have my batts on Tencha on parallel no fuse but my cables were behind my rad over my electric fan setup, covered and zip tied ..
Where do you have a 3/8 stud?
The military terminals? These little fuses can be mounted on its side no problem :D
Will do! I am picking up loom tomorrow, but from the sounds of it, even if I moved the cables to the fan shroud I would still be dangerous.
From ONSC's annual Christmas Party this past weekend. Credit to videographer @jamesurq. First attempt is in 3rd gear, then you can see me ask @jfz80 if I should try fourth, which I then did :lol: As a reference, I had her up around 3500rpm for this climb while in low range and 4th gear:
Momentum is good, lockers are better... together? Priceless.
Time for a Christmas gift for Moonshine
Mark, all you have to do is "loan" me $3k and I'll have ARBs installed before Christmas :P
Hell yeah ! this it's the kind action we ( I .? ) wanna see !
your D300 it's 4:1 ..?
I'll never be able to do that in Tencha .. ( like 3rd but never 4th gear .. )
Looks like fun. Love the cloud of black smoke 1/2 way up.
Not sure the lockers would have helped much with traction equally bad on all 4 wheels! Kind of like sand, only harder to clean!
D300 does have 4:1 gears, yup. Gotta love the 4BT torque curve!
So in that picture I've got my new ATs on. Finally got them installed after correcting my alignment.
Right after he gets a winch and lockers!
At some point in the future :D Busy working on other people's trucks for the past year and a half!!
No, he has the LowMax kit. Factory D300 low range is 2.72:1. Still a slight drop from the splitcase's 2.27:1.
What Matt said. The Low-Max gears are awesome!
The only reason I didn't jump to the 4:1 on the split case it's I found myself shifting to Hi gear several times in the trail ( when gotta move faster ) and I don't like it .. guess you need to do it often ..
Are there any dual case options with the D300?
A sweet setup would be an H55f/Blackbox/D300
I like my H55/4.7 ToyBox/Split TC with 4.56 diffs....!
Yeah I mean you're set there, it's a great case if you want center rear output but it's not necessarily worth ditching the split-case for.
I was going to put an NV4500 and Dana 300 behind my 3fe to the 80 rear until I got such a good deal on a 203/splitcase adapter from John S.
